helix_modular
Posted: Thu May 03, 2018 1:00 pm Post subject:
Yusynth on Stripboard Subject description: A growing collection of stripboard implementations with suggested mods. |
Dear EMs,
with permission of Yves Usson I intend to share my stripboard layouts of various Yusynth modules. I am very thankful for Mr. Usson's amazing work and I learned a lot in the process of designing the stripboards. Each layout has links to his homepage, after all there is the reference for wiring and the like.
All posted layouts are tested and verified.
A word on my design guidelines:
I tried to maintain a board format that fits behind a 5u standard panel in 'sandwich' configuration, much as the original designs.
The power section is intentionally very generous to be readily adapted to your needs. For my part I use 2x5 Eurorack connectors but feel free to modify. Just make sure these 10Ohm resistors are in series and the caps in parallel and grounded (!).
The provided PDFs are true to size. Print with a ratio of 1:1 and it fits your standard stripboard perfectly!
Feedback is highly welcome and appreciated. Time to give this amazing community something back!
CV Generators
Auto-bend
Dual Gated Slew
Signal processors and modifiers
MinMax
Saw Animator
Control/GATE generators and modifiers
Dual Gate Delay
Dual Pulse Delay
Clock Divider
Comparators
All the best & happy soldering,
helix modular Last edited by helix_modular on Sat Jun 29, 2019 8:11 am; edited 5 times in total |
helix_modular
helix_modular
helix_modular
helix_modular
helix_modular
billsaban
Posted: Sun May 06, 2018 1:52 pm Post subject:
| Thanx a lot for this |
helix_modular
helix_modular
MapacheRaper
Posted: Mon Jun 18, 2018 5:08 pm Post subject:
| Im loving this thread |
artilect99
Posted: Wed May 29, 2019 4:04 pm Post subject:
| Two questions... are any modifications necessary for the clock divider to run on 12V? And 2) does anyone know the what rotary switch is needed (1p12t)? |
helix_modular
Posted: Thu May 30, 2019 7:53 am Post subject:
@artilect99
I think the clock divider would work on 12V without modifications. Running Yusynth on 12V is discussed in this thread:
http://electro-music.com/forum/topic-39693.html
However, the tripping voltages for the discrete Schmitt-trigger (input processing stage) are probably a bit off (read: lower, therefore it will trigger at lower threshold). You could play around with the resistor values (R3-R6) if it does not behave as desired. If you feed it a proper pulse there should be no problem anyways.
For the switch: any one pole with up to 10 throws. The original version provides up to divide by 8, the core chip (CD4017) allows up to divide by 10 (as indicated in my upload). A 1p12t switch can probably be configured to lower throws.
Cheers |
artilect99
Posted: Fri May 31, 2019 11:06 am Post subject:
| Thanks helix. I will try it out and see if it triggers as expected. |
helix_modular
