musicatrochester
Joined: Jan 19, 2022 Posts: 2 Location: Rochester, New York, USA
Posted: Wed Jan 19, 2022 1:37 pm Post subject:
Cannot open miniAudicle's "Preferences" on macOS Big Sur Subject description: I cannot open it on either M1 or intel Chip Mac |
I got this error message on the console monitor when I tried to open "Preferences".
2022-01-19 15:17:09.028 miniAudicle[16057:5046050] *** Assertion failure in -[NSMenuItem initWithTitle:action:keyEquivalent:], NSMenuItem.m:454
I am using miniAudicle 1.4.1.0. Did anyone have the same issue? Please help if you know how to fix it. Thank you.
Ming |
musicatrochester
Posted: Wed Jan 19, 2022 2:05 pm Post subject:
More error messages on macOS Big Sur 11.6.2 (Intel) Subject description: I got more messages after I restarted my laptop. |
I got more error messages after I restart my MacBook Pro.
[chuck] 2:SYSTEM): setting log level to: 2 (SYSTEM)...
2022-01-19 16:01:11.589 miniAudicle[2135:24439] Warning: Expected min height of view: (<NSPopoverTouchBarItemButton>) to be less than or equal to 30 but got a height of 32.000000. This error will be logged once per view in violation.
2022-01-19 16:01:11.590 miniAudicle[2135:24439] Warning: Expected min height of view: (<NSButton>) to be less than or equal to 30 but got a height of 32.000000. This error will be logged once per view in violation.
2022-01-19 16:01:11.594 miniAudicle[2135:24439] Warning: Expected min height of view: (<NSPopoverTouchBarItemButton>) to be less than or equal to 30 but got a height of 32.000000. This error will be logged once per view in violation.
2022-01-19 16:01:11.596 miniAudicle[2135:24439] Warning: Expected min height of view: (<NSPopoverTouchBarItemButton>) to be less than or equal to 30 but got a height of 32.000000. This error will be logged once per view in violation.
2022-01-19 16:01:15.075 miniAudicle[2135:24439] *** Assertion failure in -[NSMenuItem initWithTitle:action:keyEquivalent:], NSMenuItem.m:454
2022-01-19 16:01:15.112 miniAudicle[2135:24439] +[NSSavePanel _warmUp] attempted warmup
2022-01-19 16:01:31.360 miniAudicle[2135:24439] *** Assertion failure in -[NSMenuItem initWithTitle:action:keyEquivalent:], NSMenuItem.m:454
2022-01-19 16:01:37.258 miniAudicle[2135:24439] _TIPropertyValueIsValid called with 4 on nil context!
2022-01-19 16:01:37.258 miniAudicle[2135:24439] imkxpc_getApplicationProperty:reply: called with incorrect property value 4, bailing.
2022-01-19 16:01:37.258 miniAudicle[2135:24439] Text input context does not respond to _valueForTIProperty:
2022-01-19 16:01:37.259 miniAudicle[2135:24439] |
TiborUdvari
Posted: Sun May 07, 2023 5:18 am Post subject:
Re: Cannot open miniAudicle's "Preferences" on macOS Big Sur Subject description: I cannot open it on either M1 or intel Chip Mac |
musicatrochester wrote: | I got this error message on the console monitor when I tried to open "Preferences".
Ming |
I have this issue when I have my airpods connected, it works fine on other headphones. |
ge
Joined: Aug 13, 2006 Posts: 108 Location: Palo Alto, CA
Posted: Sat Jun 17, 2023 12:44 am Post subject:
TiborUdvari wrote: | musicatrochester wrote: | I got this error message on the console monitor when I tried to open "Preferences".
Ming |
Both of these issues should be fixed in the latest release (1.5) of chuck. If you'd like, come check it out!
https://chuck.stanford.edu/ |
TiborUdvari
Posted: Sun Jun 18, 2023 2:55 am Post subject:
It works now! Great, thanks!
Although just as a note my airpods only seem to work with the 24kHz setting, which doesn't seem right to me, but I guess it should be. |
ge
Posted: Sun Jun 18, 2023 3:19 am Post subject:
TiborUdvari wrote: | It works now! Great, thanks!
Great to hear!
regarding the AirPods working at 24kHz setting, this may be because both your input and output are set to AirPods (?) and AirPods input is limited to 16kHz or 24kHz -- in which case chuck has to go with the lower common denominator. If you'd like, you could try using your AirPods as output device, choose a different device as your audio input device, and choose a higher sample rate. Hopefully that will allow your AirPods work (audio output only) at higher sample rates.
by the way, there is a ChucK Community Discord server now as well, please feel free to come hang, share your work, etc. https://discord.gg/ENr3nurrx8 |
