BOSS DR-110 mods
Page 3 of 3 [53 Posts]
Goto page: Previous 1, 2, 3
Psynth
PostPosted: Wed Jan 11, 2023 9:10 am    Post subject: Reply with quote  Mark this post and the followings unread
Audio noodles with my DR110 handclap module.
THe first sample is my best effort at a handclap. After about 10 secs, I lengthen the initial decay, then the echo decay, then play with the balance and tone. This is followed by the same sequence of controls but with a sawtooth as the noise source, followed in turn by a sine wave. You will also hear where I switch to using 7 rather than 3 initial triggers.
Handclap.mp3
 Filename:  Handclap.mp3
 Filesize:  1.88 MB
 Downloaded:  267 Time(s)
blakeAlbion
PostPosted: Mon Aug 28, 2023 7:21 pm    Post subject: Dependency upon digital board? Reply with quote  Mark this post and the followings unread
Hi! I have a DR-110 and really want to use its voice circuits in another drum machine. I remember doing this back in the 90s with a TR-909 and a DR-110. It was awesome to have the DR-110 voices under 909 control.
But... I can't remember how I did this. Main thing I need to know:
Will the cymbal and clap sounds work without the CPU board? Do they get noise and cymbal tones from the CPU?
I see a photo in this thread showing only the analog board.
Golly, a TR-909 had enough room I could have stuffed a whole DR-110 inside.
No, I don't have a 909 to mangle for this project. But I do have the 110.
Thanks,
Ben
blakeAlbion
PostPosted: Tue Aug 29, 2023 12:33 pm    Post subject: Reply with quote  Mark this post and the followings unread
Amazing what literacy can do.
I re-read this thread and found my answers.
I will use a xiao to trigger my claps!
