Mini synth AR trouble.
kluj
PostPosted: Sat Aug 15, 2020 7:17 pm    Post subject: Mini synth AR trouble. Reply with quote  Mark this post and the followings unread
I've combined a patched out mini-synth with the expander. As far as I can tell the AR stopped properly working once I added a +/- 15 PSU. It still gates the signal when plugged into a VCA, but without any build or decay. IC swapped out and the wiring seems fine - has anyone experienced this? I'm opting for anecdotal advice before getting into voltage testing and whatnot seeing as it was working properly when powered off of batteries. Is the higher voltage the culprit? Any advice is appreciated.
