tombola
G2 patch files: 9
richardnixon
Joined: Feb 08, 2006 Posts: 35 Location: Campbell, CA
G2 patch files: 4
Posted: Mon Jul 24, 2006 5:33 pm Post subject:
Nice patch! May not be the same thing, but it certainly gets the job done.
I had been oogling the Ringtone ever since I hear it at NAMM last year, but I opted for the Moog with the CP-251 control processor. Same situation...it's not the same thing, but it certainly gets the job done  _________________ ...if the computer will not startup, something else is wrong with the computer... |
Joined: Jan 31, 2003 Posts: 18276 Location: Durham, NC
Audio files: 233
Posted: Mon Jul 24, 2006 8:26 pm Post subject:
Great patch. The Zvex Ringtone Pedal is very cool.
I don't see why the Ringtone would sound any better than the G2. You can add other effects like filter, reverb, delay, chorus, phase shifter, etc. The G2 also has more than one waveform on the carrier. It has perfect signal suppression with the carrier is off too. Not to mention that you can save the settings of the knobs in variations. _________________ --Howard
my music and other stuff |
tombola
G2 patch files: 9
Posted: Tue Jul 25, 2006 12:49 am Post subject:
A question:
The only feature of the Zvex pedal I couldn't copy was the 'random' switch. Rather than running through the sequencer steps in order, it picks them at random.
I can think of ways to reproduce that involving lots of logic and a homebrew sequencer. But is there any easy way to do it? _________________ http://www.musicthing.co.uk/ |
Audio files: 233
Posted: Tue Jul 25, 2006 5:17 am Post subject:
Well, there are probably many ways to do that. I suggest you look at this patch, the second one posted in this topic: http://electro-music.com/forum/topic-1754.html
It uses a control sequencer. I added random movement to it, just for you. So it goes up, down, jog, or random. You can adjust the length too, but it's a little tricky. One could device a single length knob if you wanted to. I'm a bit rushed with other things at the moment.
You can take parts of this as you need them. If you just want forward or reverse stepping without up/down control, you can just use an LFO and use a saw. _________________ --Howard
Audio files: 233
Posted: Tue Jul 25, 2006 9:29 am Post subject:
BTW, I watched the Ringtone movie - a long download - and at the end the shows that if you take the four screws out of the back and adjust a trimpot with a jewlers screw driver you can adjust the mix of the multiplier output and in the input. I hope in production models he brings that out to the front panel - it's essential. _________________ --Howard
