 Forum index » Instruments and Equipment » Cwejman Sound
Who's the maker of Cwejman 3,5mm conectors?
Page 1 of 1 [3 Posts]
hassestrom
PostPosted: Fri Nov 03, 2006 5:50 pm    Post subject: Who's the maker of Cwejman 3,5mm conectors? Reply with quote  Mark this post and the followings unread
Does anyone know what the maker is?
China perhaps?
And does anyone have some *under the hood*
photos of some of the cwejman modules?
Best
monads
PostPosted: Sun Nov 05, 2006 1:11 am    Post subject: Reply with quote  Mark this post and the followings unread
Are you trying to reverse engineer the modules Confused You're best option would be to purchase a few and take them apart. The back of each module is covered with a face plate. You can get it off by bending the hooks/hinges. But I'm not going to try it on my modules Wink
hassestrom
PostPosted: Sun Nov 05, 2006 12:29 pm    Post subject: Reply with quote  Mark this post and the followings unread
No in not into any reverse engineering, i just heard about that
the modules was thin (serge thin) and they didn't use any internal
cabling wich is odd,so i was curious to see how they had solved
certain design issues in particular the combination of mini jacks,
pots and switches, since its rather difficult to match these
measurements among these components.
And inparticular if you find components that match its difficult
to get the components unless your a volume buyer, ie if you
want to build something or lets say modify a oakley module
but you want it to match the cjew design on frontpanel level.
