 Forum index » Instruments and Equipment » Cwejman Sound
ap-1 module
Page 1 of 1 [3 Posts]
Sound
PostPosted: Sun Oct 22, 2006 5:39 am    Post subject: ap-1 module Reply with quote  Mark this post and the followings unread
Could anybody explain me how works "envelope filter" Knob?
Thanks in advance.
 Filesize:  59.24 KB
 Viewed:  727 Time(s)
PostPosted: Sun Oct 22, 2006 7:48 am    Post subject: Reply with quote  Mark this post and the followings unread
It's probably similar to when you put an EQ in the sidechain of a compressor. It's a way of controling what the dynamics processor reacts to. If you set it to low pass, then it will react to the lower frequencies but not the high ones etc. Does that make sense?
Sound
PostPosted: Sun Oct 22, 2006 8:32 am    Post subject: Reply with quote  Mark this post and the followings unread
Ok! Thanks Uncle Krunkus!
And the knob works like a cutoff.
http://www.analoguehaven.com/cwejman/pdf/AP-1.pdf
