Posted: Thu Jan 03, 2008 8:17 am Post subject:
0xed - Hex editor for OSX Subject description: or other tips on how to create sysex files |
For the first time in my life I felt I really wanted to be able to send a sysex message over MIDI (the fairly simple controller snapshot request to a Nord Modular G2). Knowing what it is (just streaming a few bytes over a MIDI device), I found it was a bit more difficult than I thought it would be. First (as I am wont to do) I tried to make a Java app using javax.sound.midi.SysexMessage. Didn't get it to work. After searching around in here and on the net for a while I found "SysEx Librarian" (http://www.snoize.com/SysExLibrarian/), but that can just sent finished .syx files - there is no way to input the actual bytes that I want to send.
After some frustrating attempts at understanding hexl-mode in emacs, trying out an XCode c++ example called "HexEditView" or something, I went googling for a hex editor for OSX, and found a great one here: http://www.apple.com/downloads/macosx/development_tools/0xed.html . These things surprise me about Apple sometimes - a great many developers for Macs make slick apps that do stuff on a too high level, and finally the best low-level product can be found in Apple's yard. This is so much the opposite of what I'm used to in Microsoft-land.
I guess there is a simpler way to do it? Anyway, maybe some other sysex newbie on the Mac can be helped this technique if all else fails.
And yes I know, if you own an MS machine MIDI-OX will do all this for you. Maybe I should have skipped all this and powered up the PC instead.
Edit: Fixed 0xed link
@soundcloud @Flattr home - you can't explain music Last edited by Antimon on Fri Jan 04, 2008 6:54 am; edited 1 time in total |
BobTheDog
Posted: Fri Jan 04, 2008 3:10 am Post subject:
Hi Stefan,
That link doesn't work.
Andy |
seraph
Editor
Audio files: 33
Posted: Fri Jan 04, 2008 6:56 am Post subject:
Thanks Seraph for the alternate link. I fixed the one to Apple's site - it got confused by the full stop at the end of the link. Putting a space between the URL and the dot made it work.
