ten fingers ten toes
Posted: Wed Sep 19, 2007 1:31 am Post subject:
Problems with NOMAD in Kubuntu |
Getting the following error:
| Code: |
toad@toadbuntenu:~/nomad$ java -jar nomad.jar
Exception in thread "main" java.lang.NoClassDefFoundError: sun.misc.Service
at net.sf.nmedit.nomad.theme.plugin.ThemePluginManager.getThemes(Unknown Source)
at net.sf.nmedit.nomad.theme.plugin.ThemePluginManager.getProvider(Unknown Source)
at net.sf.nmedit.nomad.theme.plugin.ThemePluginManager.getDefaultProvider(Unknown Source)
at net.sf.nmedit.nomad.theme.plugin.ThemePluginManager.getDefaultUIFactory(Unknown Source)
at net.sf.nmedit.nomad.core.nomad.NomadEnvironment.loadDefaultFactory(Unknown Source)
at net.sf.nmedit.nomad.core.nomad.NomadEnvironment.startInternal(Unknown Source)
at net.sf.nmedit.nomad.core.nomad.NomadApplication.startInternal(Unknown Source)
at net.sf.nmedit.nomad.core.application.Application.start(Unknown Source)
at net.sf.nmedit.nomad.core.application.Application.create(Unknown Source)
at net.sf.nmedit.nomad.core.nomad.Nomad.main(Unknown Source)
toad@toadbuntenu:~/nomad$ |
Not sure where to go from here. I don't use java that often so I might have missed a library or somesuch but I've tried updating as many java runtime components and libraries as I can. I had to install the AWT-Toolkit to fix another error. |
chresan
Joined: Jul 11, 2006 Posts: 150 Location: Karlsruhe, Germany
Posted: Thu Sep 20, 2007 10:56 am Post subject:
you have to use sun-jdk to run nomad. It should work after you followed the installation steps 5-8 listed at https://jdk-distros.dev.java.net/ubuntu.html . If this does not work let me know.
Regards
Christian _________________ ----------------------
http://nmedit.sf.net |
Posted: Fri Sep 21, 2007 6:29 pm Post subject:
That got me slightly farther, I get the Nomad loading screen before it bombs out with largely the same error.
From nomad.log:
| Code: | property file:conf/application.xml
[STATUS] Loading splash:file:/home/toad/nomad/data/images/splash.jpg
[STATUS] Starting application.
conf/properties.xml (No such file or directory)
Application seems to be started the first time: using default properties.
[STATUS] [PROGRESS] Initializing
[STATUS] [PROGRESS] Images
[STATUS] [PROGRESS] Modules
[STATUS] [PROGRESS] Module builder
[STATUS] [PROGRESS] Themes
[ERR]Exception in thread "main" java.lang.NoClassDefFoundError: sun.misc.Service
[ERR] at net.sf.nmedit.nomad.theme.plugin.ThemePluginManager.getThemes(Unknown Source)
[ERR] at net.sf.nmedit.nomad.theme.plugin.ThemePluginManager.getProvider(Unknown Source)
[ERR] at net.sf.nmedit.nomad.theme.plugin.ThemePluginManager.getDefaultProvider(Unknown Source)
[ERR] at net.sf.nmedit.nomad.theme.plugin.ThemePluginManager.getDefaultUIFactory(Unknown Source)
[ERR] at net.sf.nmedit.nomad.core.nomad.NomadEnvironment.loadDefaultFactory(Unknown Source)
[ERR] at net.sf.nmedit.nomad.core.nomad.NomadEnvironment.startInternal(Unknown Source)
[ERR] at net.sf.nmedit.nomad.core.nomad.NomadApplication.startInternal(Unknown Source)
[ERR] at net.sf.nmedit.nomad.core.application.Application.start(Unknown Source)
[ERR] at net.sf.nmedit.nomad.core.application.Application.create(Unknown Source)
[ERR] at net.sf.nmedit.nomad.core.nomad.Nomad.main(Unknown Source) |
chresan
Posted: Wed Sep 26, 2007 5:43 am Post subject:
Hi, sorry for the delay. Can you run the command in a terminal and post the results here ? _________________ ----------------------
Posted: Thu Jan 31, 2008 7:50 am Post subject:
Hmm! I forgot I had this topic here. I fixed my earlier issues with the program not starting (you had the right hunch, I had an ancient version of the java binaries).
However, now I'm not able to communicate with my micro modular:
| Code: | [ERR]net.sf.nmedit.jnmprotocol.MidiException: Communication timed out.
[ERR] at net.sf.nmedit.jnmprotocol.NmProtocol.heartbeat(NmProtocol.java:57)
[ERR] at net.sf.nmedit.jsynth.clavia.nordmodular.v3_03.NordModular$NmProcotolExtension.heartbeat(NordModular.java:265)
[ERR] at net.sf.nmedit.jsynth.clavia.nordmodular.v3_03.NordModular$MessageProcessor.processMessages(NordModular.java:346)
[ERR] at net.sf.nmedit.jsynth.util.SelfRegulatingThread.run(SelfRegulatingThread.java:85)
[ERR] at net.sf.nmedit.jsynth.clavia.nordmodular.v3_03.NordModular$MessageProcessor.run(NordModular.java:314)
[ERR]Communication timed out. [ERROR:-802694390]
[OUT]Closing midi connection.
[STATUS] Stopping application...
Lots of that, no matter what midi options I choose within the program. The thing is, midi is working great for me in (the recently ported!) Renoise, so I'm pretty sure I have my interface set up correctly. |
chresan
Posted: Thu Jan 31, 2008 8:06 am Post subject:
| ten fingers ten toes wrote: | ...
At first you can check if your midi device is detected using the command
amidi -l (small L)
(The amidi command is part of a packet named alsa-utils.)
The output looks similar to:
| Code: | amidi -l
hw:2,0,0 MidiSport 8x8 MIDI 1
hw:2,0,1 MidiSport 8x8 MIDI 2
hw:2,0,2 MidiSport 8x8 MIDI 3
If your midi device has more than one In/Output pair then connect the your NM to the first In/Output Pair (the ports are usually number 1,2,...,N or A,B,...) and try again to connect Nomad with the NM (this problem is caused by a Java-Bug). If the problem still exists, post again.
Posted: Thu Jan 31, 2008 8:20 am Post subject:
Ok, still not working:
toad@toad:~$ amidi -l
Dir Device Name
IO hw:1,0,0 MidiSport 2x2 MIDI 1
IO hw:1,0,1 MidiSport 2x2 MIDI 2
I have the in/out to my Micro Modular connected on In/Out B on the Midisport, which I'm assuming are 1,0,1? It's tough to tell in nomad, because the synth setup option says "hw[1,0]" for both options!
No matter what option I chose in nomad, I get no MIDI activity lights on any of the ports. |
| Err also to clarify, I did try plugging the NM into In/Out A as you suggested, still no connection. |
chresan
Posted: Thu Jan 31, 2008 8:36 am Post subject:
| ten fingers ten toes wrote: | | Err also to clarify, I did try plugging the NM into In/Out A as you suggested, still no connection. |
The "Communication timed out." error indicates that nomad does not get a reply from the nordmodular. But it should definately work, I tested Ubuntu(6.04)+Nomad+MidiSport 2x2 myself and had no problems at all.
Using the MidiSport 2x2 you can connect only through the InA/OutA-Ports. Did you make sure that In A / Out A are selected in the Nomad connect dialog and at the MidiSport that the USB/Midi Thru button is pressed (=USB) (after pressing that button reconnect the USB-Cable)
Posted: Thu Jan 31, 2008 8:43 am Post subject:
Yes, the button is pressed, and as noted, it works fine in Renoise.
Not sure if it makes a big difference but I'm running Ubuntu 7.1...
I get nothing at all in terms of MIDI activity lights when Nomad is searching for my NM, leading me to believe it's not actually communicating with the Midisport...
The only other thing of note, I'm not using ALSA for audio at all, I have a Firewire Mixer that I have connected using freebob under jack. Not sure what sort of difference that could make, but since ALSA isn't handling my audio I figured it was worth a mention. |
chresan
Posted: Thu Jan 31, 2008 8:54 am Post subject:
I have the in/out to my Micro Modular connected on In/Out B on the Midisport, which I'm assuming are 1,0,1? It's tough to tell in nomad, because the synth setup option says "hw[1,0]" for both options! |
IO hw:1,0,0 MidiSport 2x2 MIDI 1 - this is Port A In/Out
IO hw:1,0,1 MidiSport 2x2 MIDI 2 - this is Port B In/Out
Yes the synth dialog says only hw[1,0] for both ports. The string is missing the third number. This is actually the Java-Bug because of which Port B cannot be used. I hope they fix this bug in the JRE someday
| Quote: | I get nothing at all in terms of MIDI activity lights when Nomad is searching for my NM, leading me to believe it's not actually communicating with the Midisport...
Thats interesting, I don't know if it is possible that Jack and Alsa interfere with each other but I think it is worth to check out. Can you try the following
1. disable the Jack-Daemon
2. reconnect the MidiSport USB cable
3. try to connect with Nomad _________________ ----------------------
chresan
Posted: Thu Jan 31, 2008 8:58 am Post subject:
You can also try if alsa can send messages to your midisport.
The command
amidi -p hw:0,0,1 -S F0411042110C000000000074F7
sends some random midi message to the midisport Port A (hw:0,0,1).
If you invoke that command you should see the activity leds blinking.
(Please remove the cables connected to the NM first) _________________ ----------------------
Posted: Thu Jan 31, 2008 9:02 am Post subject:
holy crap I just got it working
I noticed that my micro was in "--" mode ont he display.. I had been editing a patch in windows and had just left it there, aparently nomad didn't like that, and actually neither did my Micro! I couldn't change to a stored patch without power cycling it. However, now that I have, it's working great! |
chresan
Posted: Thu Jan 31, 2008 9:07 am Post subject:
| ten fingers ten toes wrote: | holy crap I just got it working
Haha, I like such "simple" solutions Great that it's working now.
Regards
Posted: Thu Jan 31, 2008 9:37 am Post subject:
thanks for all your help, you've been invaluable!
Im so happy now that Renoise is ported and Nomad is working, asside from a couple of VST's, I have an exact port over of all of my Windows music functionality. Im not sure Ill ever boot back into it now. |
Posted: Thu Jan 31, 2008 3:24 pm Post subject:
| ten fingers ten toes wrote: | thanks for all your help, you've been invaluable!
Now *that's* good news to me  |
