Substututes for WP20 Parts
Page 1 of 1 [5 Posts]
Juno60
PostPosted: Fri Apr 25, 2008 2:56 am    Post subject: Substututes for WP20 Parts Reply with quote  Mark this post and the followings unread
Hey@all!
I'm going to build Rays WP20, but I have some trouble getting some parts:
Capacitor: 0,02µF & 0,005µF
Potentiometer: 200k
The only values I can get are: Poti 220k and Capacitors 4,7nF & 22nF. Will they fit, too?
Regards,
Chris
Greetings from Germany,
Chris
fluxmonkey
PostPosted: Fri Apr 25, 2008 4:24 am    Post subject: Reply with quote  Mark this post and the followings unread
yes
neandrewthal
PostPosted: Fri Apr 25, 2008 10:38 am    Post subject: Reply with quote  Mark this post and the followings unread
Yeah, most pots and capacitors have wide tolerances anyway.
ChemicalKev
PostPosted: Mon Apr 28, 2008 8:22 am    Post subject: WP20
Subject description: WP20 PC board available?
I,m also very new to the synth scene and am a bit intimidated by the minisynth for the moment .The WP20,antiquated though it may, be might be easier to tackle right now.Is there aPC board for that anywhere out there or could one be coerced into making on e for a resonable fee .Or maybe a stripboard layout?
"no matter where you go, there you are."
Zodiak
PostPosted: Wed Apr 30, 2008 4:18 pm    Post subject: Reply with quote  Mark this post and the followings unread
The only thing I have seen is the PCB layout on the MFOS website
http://www.musicfromouterspace.com/analogsynth/WP20/WP20_PG1.html
You might be able to get somebody to make one up for you, even if it means drilling the holes out yourself.
Sorry but since I moved jobs I can't do it for you Sad
Stephen
www.Rainsbury.Net
