Headers/Libraries in ChucK
Page 1 of 1 [7 Posts]
Plankhead
PostPosted: Sat Jun 14, 2008 9:44 am    Post subject: Headers/Libraries in ChucK Reply with quote  Mark this post and the followings unread
I just coded up a simple controller for time signature and tempo that I'd like to include in most of my scripts. How is this usually done in ChucK? Is it possible to write "include timesig.ck" or something? Or is it more complex?
Frostburn
Audio files: 9
PostPosted: Sat Jun 14, 2008 9:57 am    Post subject: Reply with quote  Mark this post and the followings unread
It's more complex.
First you have to write the thing as a public class in it's own file. Say:
Code:
public class MyThing{ ...
in "mything.ck"
In order to use this class in a "foo.ck" you need to write a mother file that adds the class to the global namespace, yields and then adds "foo.ck".
Code:
"mything.ck" => Machine.add;
me.yield();
"foo.ck" => Machine.add;
in "mother.ck"
If you try Machine.adding "mything.ck" inside "foo.ck" you'll see some colorful error messages.
To boldly go where no man has bothered to go before.
rogan
PostPosted: Sat Jun 14, 2008 12:12 pm    Post subject: Reply with quote  Mark this post and the followings unread
Although, I should add that the use of includes is on the "to do" list. (I asked the same thing last December.)
Plankhead
PostPosted: Sat Jun 14, 2008 1:28 pm    Post subject: Reply with quote  Mark this post and the followings unread
Tried that. I ended up having to put the full path in before it would even find either file, though. I still got an error:
With:
Code:
"/Users/Zack/Documents/libMusic.ck" => Machine.add;
me.yield();
"/Users/Zack/Documents/scale.ck" => Machine.add
I got:
Code:
[chuck](VM): sporking incoming shred: 2 (mother.ck)...
[chuck](VM): sporking incoming shred: 3 (libMusic.ck)...
[scale.ck]:line(2): cannot access member 'Music.getNFreq' without object instance...
What exactly does that mean?
rogan
PostPosted: Sat Jun 14, 2008 1:43 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hi Plankhead,
Did you instantiate the object before you used it?
ie.
Code:
MyClass myObject;
5 => myObject.function();
Plankhead
PostPosted: Sat Jun 14, 2008 1:46 pm    Post subject: Reply with quote  Mark this post and the followings unread
rogan wrote:
Hi Plankhead,
ie.
Code:
MyClass myObject;
Figured that out just as you mentioned it. Thanks.
Sweet Pablo
PostPosted: Sat Jun 28, 2008 8:05 pm    Post subject: Include with CPP Reply with quote  Mark this post and the followings unread
It is possible to include files using the same way c does using c preprocessor, since chuck's syntax is basically the same as c's.
I wrote a bash script that should work for unix systems with cpp installed.
It is posted here: http://electro-music.com/forum/topic-24190.html
