 Forum index » Clavia Nord Modular » G2 Performances - Experimental
G2 Prf => Chrome
Page 1 of 1 [3 Posts]
ian-s
Audio files: 42
G2 patch files: 626
PostPosted: Fri Nov 14, 2014 5:51 pm    Post subject: G2 Prf => Chrome
Subject description: Simple test of controlling javascript browser app from Nord G2
Chrome now has experimental support for web midi.
If you have a G2 connected via MIDI to a PC running an up to date copy of the chrome browser and want to hear/see this demo...
go to chrome://flags/#enable-web-midi, enable it, and restart your Chrome browser.
Download the (old but modified) G2 prf attached here and navigate to this page.
If everything works,
    the rotating ball's hue should change with the drone harmonic content.
    The ball should kick into a random rotation direction/speed in sync with the kick drum sound.
    The balls diameter should expand in sync with the air escaping sound.
The code is horrible, just an ancient 3d random dots to surface of a sphere test with the following code dumped in. It is hard coded for midi input #1 if you have more than one midi in port connected to your PC you might need to change the index on the line inp = m.input()[n].
Code:
navigator.requestMIDIAccess().then(function (m) {
   outp = m.outputs()[1];
   inp = m.inputs()[0];
   inp.onmidimessage = function (event) {
      if (event.data[0] == 0xB0 && event.data[1] == 7)
         mHue = event.data[2]*2;
      if (event.data[0] == 0xB0 && event.data[1] == 12)
         fov = (340-(event.data[2]*.75));
      if (event.data[0] == 0x90)
         speed = Math.random()*.04, speedy = Math.random()*.04;
}, alert);
The MIDI output works as well, so it is possible to add code to control the G2 from the browser.
Normon-mid.prf2
Patch to control browser app
 Filename:  Normon-mid.prf2
 Filesize:  15.89 KB
 Downloaded:  4694 Time(s)
Electromagnetic Wave
G2 patch files: 38
PostPosted: Sun Nov 23, 2014 2:23 am    Post subject: Reply with quote  Mark this post and the followings unread
very interesting ! Thanks for this ian-s. Soon I will be able to play with the cosmos from my G2! Shocked
(picture from Prometheus movie)
 Filesize:  226.4 KB
 Viewed:  904 Time(s)
ian-s
Audio files: 42
G2 patch files: 626
PostPosted: Tue Nov 25, 2014 1:41 am    Post subject: Reply with quote  Mark this post and the followings unread
Apologies to anyone who tried this and didn't get it working.
In the short time since posting the implementation has changed a little and getting the input port is now m.input.get(n) not m.input()[n]
Code is fixed now.
I'm sure in the near future some nice things will be possible graphically. I hear native SIMD is coming to the browser soon.
