Wavetable module?
Page 1 of 1 [9 Posts]
Would you like to see a Wavetable module in the G2 if it's technically possible?
Yes
84%
 84%  [ 11 ]
No
15%
 15%  [ 2 ]
Total Votes : 13
cebec
G2 patch files: 31
PostPosted: Mon Feb 07, 2005 8:17 am    Post subject: Wavetable module? Reply with quote  Mark this post and the followings unread
Does anyone know if this is technically possible to implement on the G2?
I know there's some debate as to whether or not Wavetables violate the design philosophy of the G2. Personally, I don't think so, but I'm really just curious if the RAM used for delays and reverbs could be used for a pattern generator-style Wavetable module.
Chet
G2 patch files: 35
PostPosted: Mon Feb 07, 2005 8:23 am    Post subject: Reply with quote  Mark this post and the followings unread
I'm sure it could be done. Especially if the tables are the limited-size ones found in some vintage-style synths, like Modcan.
The tables themselves might be stored in the same flash ROM used to store patches and performances.
Good idea, and a good addition to the G2.
Roland Kuit
G2 patch files: 127
PostPosted: Mon Feb 07, 2005 8:42 am    Post subject: Reply with quote  Mark this post and the followings unread
Do you mean this?
Wavetable.pch2
pattern wavetable
 Filename:  Wavetable.pch2
 Filesize:  1.12 KB
 Downloaded:  1970 Time(s)
cebec
G2 patch files: 31
PostPosted: Mon Feb 07, 2005 9:28 am    Post subject: Reply with quote  Mark this post and the followings unread
that's great, Roland! actually, I had this sort of implementation in mind when I posted this topic. I've seen this technique in some patch last year. very interesting!
Roland Kuit
G2 patch files: 127
PostPosted: Mon Feb 07, 2005 2:32 pm    Post subject: Reply with quote  Mark this post and the followings unread
Yes, Cebec. I did use this with the NM(1). But the patch you mean was, i think, one of Wan Kempers patches for G2. You can use the same sort connection with a clocked sequencer. And thus create your own patterns:)
(with key trig reset).
cebec
G2 patch files: 31
PostPosted: Tue Feb 08, 2005 1:29 pm    Post subject: Reply with quote  Mark this post and the followings unread
Rob has a wavetable patch, too, I've found, where he clocks the Pattern Generator with an audio signal...
Does anyone know how close these types of patches are to 'proper' wavetable synthesis? I've read some articles on the subject but am none the wiser.
Also, is there a specific reason why you chose 16 for the pattern length versus 128? Besides lowering the pitch and requiring readjustment, a setting of 128 seems to make for a longer, higher-res waveform...
I noticed something funny, though, about these patches. The 'step/prob' modulation input seems 'dead'. I've tried on both the G2 demo software and my G2 and can't affect step/prob amount with an LFO or Oscillator.
Moving the knob, itself, not the modulation amount knob, results in some interesting timbral changes. I suppose I could use a MIDI control send to do this, but I'm curious as to why I can't get the mod. input to work.
EDIT: Ah, it seems that input is only 'live' when in the RndPatternGenerator's Mode 2... hmm... but why?
cappy2112
PostPosted: Thu Apr 28, 2005 2:22 pm    Post subject: Re: Wavetable module? Reply with quote  Mark this post and the followings unread
How about a Waldorf module, that minimally emulates the Microwave XT? Smile
PostPosted: Thu Apr 28, 2005 7:46 pm    Post subject: Reply with quote  Mark this post and the followings unread
You almost said the words yourself .. "trade off".
If it is indeed so it seems more like a bug, interesting, I love other people's bugs :-) **1)
Jan.
**1) probalbly something we (or I) as human(s), inherited from our (my) forefathers (mothers), ehm either apes or monkeys, I allways mix those up. Apemonkeys, nit picking, love.
Fozzie
G2 patch files: 49
PostPosted: Fri Apr 29, 2005 6:49 am    Post subject: Reply with quote  Mark this post and the followings unread
I'm very curious about how the wavetable stuff is implemented on the new clavia stage thingy. Some waldorf-like wavetable implementation would have my attention for sure!! I don't regard microwave(XT) synths to be samplers, so I say no problem to put it in a G2 (regarding paradigm/principle). But then again, I'm a pragmatic synthesist Cool (if I can call myself a synthesist at all).
