lfo frequency cutoff controlled by mouse?
Page 1 of 1 [9 Posts]
christorb
PostPosted: Mon Apr 26, 2010 11:39 am    Post subject: lfo frequency cutoff controlled by mouse?
Subject description: changing the frequency cutoff of an lfo with mouse movement?
Hi all,
I'm pretty new to Chuck and am just experimenting with it at the moment. I was wondering if there's a way to get Chuck to enable you to control the cutoff of an LFO by mouse movement - perhaps by moving the mouse up, you increase the cutoff, and obviously when you move it down you'd decrease the cutoff...
Thanks,
Chris
vrachnasormora
PostPosted: Mon Apr 26, 2010 12:45 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hi Chris, can you please show me your code so far?By cutoff you mean the frequency of a filter modulated by an LFO or the speed of the LFO itself?Show me where you are so I can help you or I can send you some code if you like, but first I need to know what you mean by cutoff.Using the mouse it's very easy to control any parameter.
Andreas
christorb
PostPosted: Tue Apr 27, 2010 2:55 am    Post subject: Reply with quote  Mark this post and the followings unread
Ok, here's my code -
[10,13,15,12,15,17,16,18,15,13,11] @=> int notes[];
1::second => dur T;
T - (now % T) => now;
int i;
Phasor o1 => HPF f1 => JCRev r1 => dac;
//osc gain
.5 => o1.gain;
//reverb 'amount'
.1 => r1.mix;
//filter frequency
1000 => f1.freq;
//lfo oscillator
SinOsc lfo1 => blackhole;
5 => lfo1.freq;
//infinite loop
while (true)
for (0 => int i; i <notes> o1.freq;
150::ms => now;
if(Std.randf() > -.01) .01::T => now;
else .01::T => now;
(lfo1.last()*500) + 1000 => f1.freq;
What I actually meant was that I'd like to be able to use mouse movement to control the frequency of the filter - my brain wasn't having a good day yesterday! I've got an lfo here, but it doesn't seem to work properly - it changes the filter frequency only after every cycle of notes...
I'm not very good at this stuff :S!
vrachnasormora
PostPosted: Tue Apr 27, 2010 5:35 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi Chris, here I use a variable named center_filter_freq in order to modulate the filter frequency by LFO and by mouse in two diffrerent functions sporked together before the main loop.So if this is what you are after:
Code:
Hid hid;
HidMsg msg;
hid.openMouse( 0 );
1::second => dur T;
int i;
//osc gain
.5 => o1.gain;
//reverb 'amount'
.1 => r1.mix;
//filter frequency
1000. => float center_filter_freq;
//lfo oscillator
5 => lfo1.freq;
spork~ lfo_to_filter();
spork~ mouse_to_filter( 500, 5000 );
//infinite loop
while (true)
        150::ms => now;
//if(Std.randf() > -.01) .01::T => now;
//else .01::T => now;
fun void lfo_to_filter()
    while ( true )
        (lfo1.last()*500) + center_filter_freq => f1.freq;
        100::ms => now;
fun void mouse_to_filter( float min, float max )
    while ( true )
        hid => now;
        while ( hid.recv( msg ) )
            if ( msg.isMouseMotion() )
                if ( msg.deltaY )
                    if ( msg.deltaY <0> center_filter_freq;
                        if ( center_filter_freq > max )
                            max => center_filter_freq;
                    if ( msg.deltaY > 0 )
                        10 -=> center_filter_freq;
                        if ( center_filter_freq <min> center_filter_freq;
                    <<<center_filter_freq>>>;
vrachnasormora
PostPosted: Tue Apr 27, 2010 5:51 am    Post subject: Reply with quote  Mark this post and the followings unread
I'm sorry I forgot to disable HTML in the previous post.So that would be:
Code:
Hid hid;
HidMsg msg;
hid.openMouse( 0 );
1::second => dur T;
int i;
//osc gain
.5 => o1.gain;
//reverb 'amount'
.1 => r1.mix;
//filter frequency
//lfo oscillator
5 => lfo1.freq;
//infinite loop
while (true)
    for (0 => int i; i <notes.size(); i++ )
        Std.mtof(notes[i]) => o1.freq;
        150::ms => now;
    while ( true )
        100::ms => now;
    while ( true )
        hid => now;
                if ( msg.deltaY )
                    if ( msg.deltaY < 0 )
                        10 +=> center_filter_freq;
                        if ( center_filter_freq < min )
                            min => center_filter_freq;
                    <<< center_filter_freq >>>;
christorb
PostPosted: Tue Apr 27, 2010 6:15 am    Post subject: Reply with quote  Mark this post and the followings unread
That's cool Smile, I can hear the effect of moving the mouse on the filter cutoff, though for some reason the notes have disappeared, replaced by what seems to be a rapid series of impulses. Would it be better do you think to remove the lfo, and just have the mouse control the filter frequency cutoff?
Sorry, I know I'm a bit of a noob with all this!
vrachnasormora
PostPosted: Tue Apr 27, 2010 6:32 am    Post subject: Reply with quote  Mark this post and the followings unread
Well it seems that you also forgot to disable HTML in your post with the code so I modified the main loop with Std.mtof but of course the values in the array are low for midi notes ( I guess ) so they could be heard as pulses.You don't need to remove the lfo ,its contribution is subtle
christorb
PostPosted: Tue Apr 27, 2010 7:30 am    Post subject: Reply with quote  Mark this post and the followings unread
Ah, yeah - the notes were too low! This is exactly what I was looking for!
Might see if I can get something else going with the x axis of the mouse too...
Many thanks Smile
PostPosted: Tue Apr 27, 2010 11:09 am    Post subject: Reply with quote  Mark this post and the followings unread
Just want to mention that ChucK can actually identify several different mice (at least in my experiments on the Mac). Example:
    mouse 1 Y controls cutoff of a filter
    mouse 1 X controls resonance of same filter
    mouse 2 Y controls frequency of oscillator 1
    mouse 2 X controls frequency of oscillator 2
You do this by incrementing the argument to hid.openMouse(), so hid.openMouse(0) accesses one mouse and hid.openMouse(1) accesses another.
/Stefan
