 Forum index » Clavia Nord Modular » G2 Patches - Completed » Organs
B3-like organ + Leslie
ZeeByeZon
PostPosted: Sat Jan 23, 2010 11:14 am    Post subject: B3-like organ + Leslie
Subject description: My Hammond organ patch
Hi there!
I just completed my organ performance patch.
The 2 manuals of the B3 are there (upper with perc), you can split the keyboard Smile
You can use the expression pedal. On the G2X, use the Global modulation wheels for Leslie control (1 for bypass, 2 for speed control).
Have a look on the Global panel too...
I copied Chet's scanner vibrato (thank you, hope this does not disturb you), I have some ideas to make one even more realistic.. may be later...
The Leslie is mine, I did it on my Micro modular a couple of years ago Smile
There are some issues with the oscillator phase when you play both manuals simultaneously with similar settings... If you have any solution...
I tried to as much polyphony as possible. I have 10 voices on each manual (20 voices total) on my G2X. You can still disable a manual slot to get more on the remaining. With the upper only I get 19, and with the lower only I get 20.
I hope you will enjoy this one.
B3+Leslie.prf2
2-manual hammond B3 emulation with scanner vibrato/chorus and Leslie speaker with overdrive.
10 voices on each manual with the expansion board.
Slot 1 is the lower manual.
Slot 2 is the Leslie (+ overdrive)
Slot 3 is the upper manual
Slot 4 is the vibrato
 Filename:  B3+Leslie.prf2
 Filesize:  11.92 KB
 Downloaded:  2091 Time(s)
