 Forum index » Clavia Nord Modular » Nomad - NM1 Open Source Editor
why cant i open any patch?
Page 1 of 1 [9 Posts]
Muzik 4 Machines
PostPosted: Sun May 05, 2013 1:33 pm    Post subject: why cant i open any patch? Reply with quote  Mark this post and the followings unread
i get the same error on EVERY one of my patches
Code:
net.sf.nmedit.jpatch.clavia.nordmodular.parser.ParseException: error@259:0: expected '/' (<end>), found <EOF>
   at net.sf.nmedit.jpatch.clavia.nordmodular.parser.PParser.emiterror(PParser.java:160)
   at net.sf.nmedit.jpatch.clavia.nordmodular.parser.PParser.emiterror(PParser.java:178)
   at net.sf.nmedit.jpatch.clavia.nordmodular.parser.PParser.sections(PParser.java:275)
   at net.sf.nmedit.jpatch.clavia.nordmodular.parser.PParser.parse(PParser.java:206)
   at net.sf.nmedit.jsynth.clavia.nordmodular.utils.NmUtils.parsePatch(NmUtils.java:453)
   at net.sf.nmedit.jpatch.clavia.nordmodular.NMPatch.createPatchFromFile(NMPatch.java:521)
   at net.sf.nmedit.nordmodular.NmFileService.openPatch(NmFileService.java:80)
   at net.sf.nmedit.nordmodular.NmFileService.open(NmFileService.java:137)
   at net.sf.nmedit.nomad.core.Nomad.openOrSelect(Nomad.java:946)
   at net.sf.nmedit.nomad.core.swing.explorer.FileNode$3.run(FileNode.java:380)
   at net.sf.nmedit.nmutils.swing.WorkIndicator$WrappedRunnable.run(WorkIndicator.java:60)
   at java.awt.event.InvocationEvent.dispatch(InvocationEvent.java:209)
   at java.awt.EventQueue.dispatchEventImpl(EventQueue.java:708)
   at java.awt.EventQueue.access$400(EventQueue.java:82)
   at java.awt.EventQueue$2.run(EventQueue.java:669)
   at java.awt.EventQueue$2.run(EventQueue.java:667)
   at java.security.AccessController.doPrivileged(Native Method)
   at java.security.AccessControlContext$1.doIntersectionPrivilege(AccessControlContext.java:87)
   at java.awt.EventQueue.dispatchEvent(EventQueue.java:678)
   at java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:296)
   at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:211)
   at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:201)
   at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:196)
   at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:188)
   at java.awt.EventDispatchThread.run(EventDispatchThread.java:122)
[/img]
PostPosted: Sun May 05, 2013 3:01 pm    Post subject: Reply with quote  Mark this post and the followings unread
I don't know, could you post one of those patches here so I could see it or try to open it in the Clavia editor?
Muzik 4 Machines
PostPosted: Sun May 05, 2013 3:02 pm    Post subject: Reply with quote  Mark this post and the followings unread
see attachement
its just a random patch from the folder, but every patch i tried (i tried over 100) gave me the error, be it my own patches, the factory presets, or any patch from clavia site
Noisypad.pch
 Filename:  Noisypad.pch
 Filesize:  2.65 KB
 Downloaded:  696 Time(s)
PostPosted: Sun May 05, 2013 3:07 pm    Post subject: Reply with quote  Mark this post and the followings unread
Ok .. that one is
Code:
Version=Nord Modular patch 1.10
Nomad can only handle 3.0x patches ... I read your comment in the other thread too, but unfortunately the Clavia software is the only software able to do the conversion ... however a lot of patches had been converted .. there is an URL in that other thread I think ...
Muzik 4 Machines
PostPosted: Sun May 05, 2013 3:08 pm    Post subject: Reply with quote  Mark this post and the followings unread
but all my own are 3.03 and still cant be opened Sad
Could you post an example of one of those too?
Muzik 4 Machines
PostPosted: Sun May 05, 2013 3:11 pm    Post subject: Reply with quote  Mark this post and the followings unread
i'll post some tonight as i'm not home now and those patches of mine are from a network drive at home, so ill post some later, thanks
i'm really pissed at clavia today for being too lame to make a non PPC editor after all this time
PostPosted: Sun May 05, 2013 3:15 pm    Post subject: Reply with quote  Mark this post and the followings unread
It's getting late here so probably it will be tomorrow before I can check it out then ... heh ... I already thought I sensed some frustration ... will try to help you out though Laughing
Muzik 4 Machines
PostPosted: Sun May 05, 2013 3:20 pm    Post subject: Reply with quote  Mark this post and the followings unread
thanks, im pissed cause i bought a new laptop that costed like 3 months rent, and i cant use the most basic software on it (and i just needed to change a pitch bend range in 1 patch lol)
thanks for your help, and no worry if its tomorrow, i think i will need to just buy a new hardrive for my (i thought) garbage laptop (i guess i will still need it after all if i want a working editor)
