Decoupling Caps on Power Rails
Page 1 of 1 [4 Posts]
Broadwave
Audio files: 6
PostPosted: Sat Jan 22, 2011 2:49 am    Post subject: Decoupling Caps on Power Rails Reply with quote  Mark this post and the followings unread
In the excitement that all my modules actually work, I've ignored the fact that I'm getting LFO and Envelope modulation breakthrough on my VCO's, even though they're not patched in... which is now becoming annoying.
The main PSU is well smoothed, but even if I'm only running one VCO and one LFO, I'm still getting a very, very slight modulation on the VCO output.
All my individual module power rails are decoupled with a 10uf elec cap (most of Ray Wilson's circuits use this, so I presumed it would be ok), but I'm wondering if it's enough, as I noticed that the original circuit I have for the Korg LFO is decoupled with a 100uf cap followed by a 100n poly.
Is there a cure for my woes?
Andy.
Synth DIY Projects
Musical Doodlings
Sound
PostPosted: Sat Jan 22, 2011 3:19 am    Post subject: Reply with quote  Mark this post and the followings unread
Hello,
What oscillators do you listen the modulation?
What LFOs or envelopes modulate the VCO's?
What power supply are u using?
Could you check with a oscilloscope the positive and negative rails? In which of them is present the modulating signal?
LektroiD
PostPosted: Sat Jan 22, 2011 5:23 pm    Post subject: Reply with quote  Mark this post and the followings unread
I had the same problem, it turned out the PSU just couldn't cope with the draw all the circuits were pulling from it.. try disconnecting a couple of hungrier modules and the problem should subside. If this is the case, a second supply is needed.
LektroiD
frijitz
Audio files: 54
PostPosted: Sat Jan 22, 2011 9:11 pm    Post subject: Re: Decoupling Caps on Power Rails Reply with quote  Mark this post and the followings unread
At LFO frequencies PS decoupling caps can't do much. The main problem is usually power supply routing -- chunky leads and a star grounding system usually get rid of most of this kind of problem.
Ian
