today> Various Artists NYE concert
Ubuntu 64 bit binary
Page 1 of 1 [12 Posts]
frabato
PostPosted: Mon Jun 20, 2011 6:21 pm    Post subject: Ubuntu 64 bit binary Reply with quote  Mark this post and the followings unread
Hi All,
I'm on ubuntu 11.04 64 bit and I installed chuck 1.2.0.8 from the standard repository. Now I have heard that chuck wasn't ready for 64 bit but I thought I'd give it a try anyway. I started qjackctl and
Code:
a@Astudio:~$ chuck --shell
jack sees the audio ports no problem. But then I try
Code:
welcome to chuck shell!
chuck %> SinOsc s => dac;
SinOsc: command not found
chuck %>
I have no experience with chuck or programming languages of any sort so maybe I'm doing something silly or maybe it really isn't working right. If it isn't working properly, would someone please recommend a distribution that they have had success with, maybe ubuntu 32 bit or??????
I'll try building it from source if anyone thinks that that would help.
Thanks
To add to the 64 bit mystery I see that puredyne includes chuck in their 64 bit version
frabato
PostPosted: Mon Jun 20, 2011 8:11 pm    Post subject: Reply with quote  Mark this post and the followings unread
I just tried puredyne 32 and 64 and I get the same unsuccessful results. These both use ubuntu binaries 1.2.0.8. so maybe there is something wrong there. Am I missing a step? Here's what I've done.
1) start jack and change to 48000
2) chuck --shell
3) SinOsc s => dac;
result is:
I am a super n00b so please don't rule out something incredibly lame.
Thanks
PostPosted: Tue Jun 21, 2011 1:40 am    Post subject: Reply with quote  Mark this post and the followings unread
Ok I'm a noob when it comes to the chuck shell, but since you say you are a noob too - have you got that routine working on another platform?
What happens if you write this in a file called test.ck:
Code:
SinOsc s => dac;
2:.second => now;
and the on the prompt write:
Code:
chuck test.ck
frabato
PostPosted: Tue Jun 21, 2011 6:48 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks for the reply, both of those bits of code returned the same thing, "command not found". Everything I've tried from the examples at:
http://chuck.cs.princeton.edu/doc/examples/ has returned "command not found". What I'm trying to figure out is weather or not the program is defective or am I missing a step(s). Once a person is in the chuck shell should it return something other than "command not found" when you enter
Code:
SinOsc s => dac;
2:.second => now;
or
chuck test.ck
or
5::second + now => time later;
while( now < later )
    <<<now>>>;
    1::second => now;
<<<now>>>;
or whatever. Am I missing something? And no, I don't have it working on another platform. I'll try windows 7.
Thanks
frabato
PostPosted: Tue Jun 21, 2011 7:00 am    Post subject: Reply with quote  Mark this post and the followings unread
Well I get "command not found" on windows 7 as well, so I feel fairly certain that I am doing something wrong. Am I supposed to be entering these commands in the chuck shell or should I be writing them to a file somewhere?
Can anyone recommend a tutorial for a complete beginner?
Thanks
PostPosted: Tue Jun 21, 2011 7:48 am    Post subject: Reply with quote  Mark this post and the followings unread
You could try point 7. here http://chuck.cs.princeton.edu/doc/build/
Maybe I should point out that I don't really know what chuck shell is (though I've coded a lot of chuck). My example above assumed that you ran:
Code:
chuck test.ck
from a command line without first having started chuck. Maybe your command line can't find the chuck program?
From higher up on that link:
On Windows: put bin\chuck.exe in c:\windows\system32\. To run under windows: use start->run: cmd (or use cygwin)
At this point, you should be able to invoke 'chuck' from either Terminal (in OSX) or 'cmd' under windowsm, from any directory
.. meaning you write just "chuck" on the command line.
frabato
PostPosted: Tue Jun 21, 2011 9:42 am    Post subject: Reply with quote  Mark this post and the followings unread
Hey, thanks again for the reply. When I use the terminal without being in the chuck shell I get:
Code:
a@Astudio:~$ chuck test.ck
[test.ck]: no such file or directory
but chuck is in my path at /usr/bin/chuck.
I was able to play the examples by cd'ing into that directoy.
Code:
a@Astudio:~$ cd /A/pkgsrc/chuck-1.2.1.3/examples
a@Astudio:/A/pkgsrc/chuck-1.2.1.3/examples$ chuck hanoi++.ck
and I was able to get sound in windows 7 by pasting the code into miniAudicle.
so that brings up the question again, do I have to save things like:
Code:
SinOsc s => dac;
2:.second => now;
into a file first or are you just typing this stuff into a terminal?
Thanks, I'm getting closer
Thanks
PostPosted: Tue Jun 21, 2011 2:00 pm    Post subject: Reply with quote  Mark this post and the followings unread
Save it to a file! Smile
if you type:
Code:
echo $PATH
on a linux prompt, what do you get?
/Stefan
frabato
PostPosted: Tue Jun 21, 2011 2:39 pm    Post subject: Reply with quote  Mark this post and the followings unread
Code:
a@Astudio:~$ echo $PATH
/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games
I created a file in my home directory named "a.ck" and I've pasted may examples into it and when I run
Code:
chuck a.ck
everything plays fine. I can see where miniAudicle would be a help but I haven't been able to build it on ubuntu 11.04 64 bit. Maybe I'll try puredyne 32 bit. Anyway, thanks so much for getting me going.
PostPosted: Tue Jun 21, 2011 11:02 pm    Post subject: Reply with quote  Mark this post and the followings unread
Nice! I think the Mini Audicle is Mac-only.
/Stefan
GrandJu
PostPosted: Wed Jun 22, 2011 12:33 pm    Post subject: Reply with quote  Mark this post and the followings unread
Mini Audicle works on Windows XP too.
I don't know for linux...
Ju
PostPosted: Wed Jun 22, 2011 2:01 pm    Post subject: Reply with quote  Mark this post and the followings unread
Oh oops, sorry.
