G2 Editor on Tablet??
Page 1 of 1 [12 Posts]
iPassenger
G2 patch files: 78
PostPosted: Fri Nov 25, 2011 2:08 am    Post subject: G2 Editor on Tablet?? Reply with quote  Mark this post and the followings unread
Has anyone managed to get the G2 Editor to work on a tablet pc?
I've been thinking lately that having a small tablet with the editor running on it would mean I could have full control of my G2 Engine without switching my desktop pc on at all. Another step closer to my computer-less studio dream.
I appreciate that perhaps tablets aren't the best interface for turning the dials etc but the form factor and just that it could be switched on and off when needed would be nice.
Ross
iP (Ross)
Estarriol
PostPosted: Fri Nov 25, 2011 9:40 am    Post subject: Reply with quote  Mark this post and the followings unread
Patching on a 10" display (or less) is a pain in da ...rear. You need a windows tablet, I heard iRos PD10 not bad.
iPassenger
G2 patch files: 78
PostPosted: Sun Nov 27, 2011 4:49 am    Post subject: Reply with quote  Mark this post and the followings unread
Hmm.. yes small screens are not what you really want..
So what i really want is a 32inch tablet! lol.
mmm... maybe my plan isn'ty so great. Sad
iP (Ross)
ian-s
Audio files: 42
G2 patch files: 626
PostPosted: Sun Nov 27, 2011 12:10 pm    Post subject: Reply with quote  Mark this post and the followings unread
The HP touchsmart range seems to be significantly discounted now. I think some models are 'all in one' so might be a good option.
Seems the format is not very ergonomic for general use but I imagine it would be ideal for a dedicated NM patching PC.
dorremifasol
G2 patch files: 49
PostPosted: Sun Nov 27, 2011 3:27 pm    Post subject: Reply with quote  Mark this post and the followings unread
I would love to patch using this one:
http://www.youtube.com/watch?v=5s5EvhHy7eQ
After 2nd minute it gets particularly interesting Smile
Albert
ian-s
Audio files: 42
G2 patch files: 626
PostPosted: Sun Nov 27, 2011 6:00 pm    Post subject: Reply with quote  Mark this post and the followings unread
Very nice
I wonder if you could use rear projection and have a couple of knobs (two halves held together with magnets, the sides that touch the front and back of the screen covered in felt) which can slide over the screen. Slide a physical knob over an onscreen knob and just turn to adjust. Each knob would use two of the four tracking points.
Would need a multi-touch aware version of the editor though.
PostPosted: Sun Nov 27, 2011 8:37 pm    Post subject: Reply with quote  Mark this post and the followings unread
I would suggest either:
a.) Running VPN or other remote software on a tablet, talking to another computer that runs the editor
b.) getting a touch-screen capable monitor (they are hard to find smaller than 23"). But you can find "multi-touch" (supports gestures, not completely separate finger tracking) for $200-300 US. HP, Dell, and others make them.
c.) If you just need a live interface, and not for patching, running something to translate OSC to MIDI (not necessary, but then you can do this:)
- run TouchOSC on an iPad
- run reacTIVision on a DIY projector/multi-touch surface (http://reactivision.sourceforge.net/).
Maybe the new editor in the works will support OSC or multi-touch controls. One can hope Smile
iPassenger
G2 patch files: 78
PostPosted: Mon Nov 28, 2011 3:03 am    Post subject: Reply with quote  Mark this post and the followings unread
Interesting ideas but none of them are screaming out to me.
I like the sound of option B but then that still requires the computer to be on.
I'm beginning to think the solution isn't out there yet.
iP (Ross)
iPassenger
G2 patch files: 78
Thanks for giving me something to think about everyone. Smile
iP (Ross)
cappy2112
PostPosted: Mon Nov 28, 2011 8:14 am    Post subject: Reply with quote  Mark this post and the followings unread
Which new editor in the works are you referring to? Nomad?
PostPosted: Mon Nov 28, 2011 11:06 am    Post subject: Reply with quote  Mark this post and the followings unread
This one:
http://electro-music.com/forum/topic-48872.html
And someone else likes the idea of a touch controller (though not for patching):
http://electro-music.com/forum/topic-49752.html&sid=4678ede0ff12e76413583fd973f5cec3
I have an iPad now, and running TouchOSC to control ableton live. I love the interface. Through that, I can control the G2 also, but it would be so much nicer if the editor can talk OSC...at least for the parameter page so that display info can be updated with names, values, etc. I am thinking of a VST in MAX4Live that would do something similar...but there's no easy way without talking to the G2 via USB, or the editor directly.
lambshain
PostPosted: Mon Dec 05, 2011 11:02 pm    Post subject: Reply with quote  Mark this post and the followings unread
the ibm x61t is an option. some modls have also finger touch,
but only 1 point at the same time.
