 Forum index » Instruments and Equipment » Chameleon
Anybody using the Fahrenheit Skin ?
Page 1 of 1 [7 Posts]
hurolura
PostPosted: Mon Apr 05, 2010 2:46 am    Post subject: Anybody using the Fahrenheit Skin ? Reply with quote  Mark this post and the followings unread
As the topic subject tells ...
Are there any Farhenheit user here ...
Any advice, typical use ...
Breathe life into your sound:
http://www.aodyo.com
hurolura
PostPosted: Mon Apr 19, 2010 3:08 pm    Post subject: Reply with quote  Mark this post and the followings unread
Nobody then ?
Any midi controller template ?
outgo
PostPosted: Wed Apr 21, 2010 12:09 am    Post subject: Reply with quote  Mark this post and the followings unread
bonjour,
i actually used to use it quite a lot but the got annoyed by the long loading time since I use Infiltrator more often.
it's fun to really use it standalone live with a sequencer. I uses an emu command station and an akai MPC for that.
the cc are easy to set up even without a template.
you can do quite a lot with fahrenheit since the mixer is sophisticated.
any more questions let me know...
ingo
hurolura
PostPosted: Wed Apr 21, 2010 4:36 am    Post subject: Reply with quote  Mark this post and the followings unread
Hallo,
I was thinking about preparing a template for my MPD32 to get control other the sounds. Alternatively a BCR 2000 could also do the job. Or combine them.
Or I could build a dedicated MIDIBOX...
Only thing I would miss would be the sequencer then...
My question was more to get feedback about daily use experience before setting up a solution.
Something like this could be a solution to remote control the Fahreheirt skin for the Chameleon
 Filesize:  77.42 KB
 Viewed:  818 Time(s)
outgo
PostPosted: Thu Apr 22, 2010 12:57 pm    Post subject: Reply with quote  Mark this post and the followings unread
why don't you just use the G2 for sequencing and controlling Fahrenheit?
should work perfectly.
hurolura
PostPosted: Thu Apr 22, 2010 1:39 pm    Post subject: Reply with quote  Mark this post and the followings unread
Yep good idea.
I will try it !!!
clementshawes
PostPosted: Thu Apr 19, 2012 8:25 am    Post subject: Reply with quote  Mark this post and the followings unread
Apologies for rekindling an old thread here but I just wanted to say that I've had a LOT of fun using this skin in 2 different setups...
With Ableton Live using either an Akai APC(40) or Novation LaunchPad with one of the many Step-Sequencer scripts (highly recommend the NativeKontrol scripts for the LaunchPad)
And
Playing notes/sequencing with my Akai MPC 1000 but with a Native Instruments Kore hardware controller (standalone).
I hope to do more with this - hopefully to do something with the Lemur iPad app...
