Streaming now
<on air> Various Artists NYE concert
Anyone doing classical/orchestral work using synths?
Page 1 of 1 [10 Posts]
briandc
PostPosted: Wed Jun 15, 2016 8:23 am    Post subject: Anyone doing classical/orchestral work using synths? Reply with quote  Mark this post and the followings unread
Hi all,
I'm currently interested in doing some orchestral and/or classical-style things, using synth-based sounds (not samples of traditional orchestral instruments).
Anyone here doing something of this sort?
brian
Make your PC happy: use linux!
LinuxSynths.com
PostPosted: Thu Jun 16, 2016 7:10 am    Post subject: Reply with quote  Mark this post and the followings unread
Kevin Haller did a version of the 1812 overture a few years ago. As best as I recall, he used synth sounds, not samples. Are you looking for models to listen to for your own ideas? There have been a number of commercial recordings of classical music using synths, too. Carlos, Tomita, and ELP come to mind off the top of my head, but I am sure there are others
Someone here posted an original composition that might be useful for ideas--I think it was a chromatic-based fugue. [edit: See link below.]
Of course, there are probably hundreds of thousands of midi files (maybe more) of classical and classical style music that were probably created for use with synth sounds.
Years ago, I created a track template in Cakewalk [now known as SONAR] that paralleled a mini-orchestra score with the intent of orchestrating one of of my very early pencil-and-paper sketches. I am not sure how far I got.
At the first electro-music festival I went to, I had a conversation with someone who (IIRC) used Cakewalk's CAL scripting language as sort of motivic macros.
Not sure if any of this helps, but if you are looking to discuss techniques, I'd be interested in seeing what you and others do.
Steve
Addendum:
I started looking for the tunes I mentioned and also found this:http://electro-music.com/forum/topic-19476.html from Kevin Kissenger.
Chromatic Fugato from Bachus can be found here: http://electro-music.com/forum/phpbb-files/chromatic_fugato_rmx_210.mp3 But now that I listen to it, it might use a sampler, a rompler, or another source of real acoustic instruments.
I hope you don't mind my posting links to pieces done by members of the community and available here. This seems like a good thread for them.
briandc
PostPosted: Thu Jun 16, 2016 10:22 am    Post subject: Reply with quote  Mark this post and the followings unread
Steve
Addendum:
Hi Steve,
thanks for responding.
I am familiar with some of the names you mentioned, yes. Carlos' work seemed all too mechnical, from what I recall. (I suppose it was midi'd rather than realtime performance.)
In fact, I'm not interested in midi files, but rather realtime performance, music a bit more "traditional" but with synth sounds. (I did listen to the Chromatic Fugato, btw. Thank you! It was nice, although I agree that it was probably more sampled instruments than not.)
One work I came across online was Gary Numan's rendition of Satie's First Gymnopedie, here: Numan
I have a kind of template of instruments that I like, which I used to make a song for a video you can see here: ValleOlona
Yes, I'd love to discuss techniques! Wink
brian
LinuxSynths.com
A E J O T Z
Audio files: 148
PostPosted: Mon Jun 19, 2017 5:33 pm    Post subject: Reply with quote  Mark this post and the followings unread
Joss Bordelon from Boston sent me the following music to air on my streaming-on-demand synthetic music show, Satellite 5 (sat-5.com).
I don't know if she hand played it all or used a MIDI file and I don't care. It's a badass ten minutes of classitronica.
https://soundcloud.com/jossbordelon/prokofiev-op10
AEJOTZ is pronounced "A-Jotz"
retro-futurism now
electronics = magic
free albums at http://aejotz.bandcamp.com
listen to genre-defying synthetic music at http://sat-5.com
briandc
PostPosted: Wed Jun 21, 2017 2:07 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hi A E J O T Z,
thanks for the link. The rendition wasn't quite my style, but definitely in the right direction! Smile
I am currently listening to some audio stuff on your website, and truly enjoying it. I'm glad to have learned of you/it! Thanks!
brian
LinuxSynths.com
Lonzenator
PostPosted: Sun Dec 03, 2017 6:26 am    Post subject: Finally a place i might find like interests Reply with quote  Mark this post and the followings unread
I grew up like most pianists, classically trained, studied applied piano and composition while at the university, though degree is a clinical thing. I have been interested in and working on pieces that tend to follow the structure of more romantic era music (Beethoven, Chopin and so forth). Am looking to collaborate with others on projects like these.
JovianPyx
Audio files: 224
PostPosted: Sun Dec 03, 2017 10:15 am    Post subject: Reply with quote  Mark this post and the followings unread
I've done some sequences using MIDI files of various artists including Bach (who technically is not classical) and Chopin. I did Chopin's Mazurkas on a DIY digital Karplus-Strong synth which can have a very harp-like timbre (16 voice polyphonic). Lot's of fun to do and hear. I cannot play keyboard well enough to do this stuff myself, but I discovered many sources of MIDI files. Some are better than others, some need only minor adjustments. Also one of Bach's Brandenburg Concertos using various DIY digital synths including a 192 voice karplus-strong.
Time flies like a banana.
corruptio optimi pessima
L´Andratté
PostPosted: Thu Mar 22, 2018 8:46 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi briandc, I am only superficially informed about the work of Wendy Carlos, but I think it is mostly sequenced and multitracked, MIDI is a child of the 80s iirc.
To be honest, I am put off by most of the classical composition synth interpretations that I came across, but that is not an ideological thing, I just find most interpretations too close to technical exercises, the timbres too flat, the human feel missing.
Please prove me wrong! Wink
Digiton
PostPosted: Mon Jun 25, 2018 10:32 am    Post subject: Reply with quote  Mark this post and the followings unread
Maybe too close to traditional sample based instrument players, but I have used SYNFUL orchestra a lot in the past. It has a library of orchsetral instruments you choose from but they are derived from additive synthesis - not sample playback.
The interesting thing about it is for whatever reason, some modulation produce incredibly violent feedback and distorted sound. Its fun to play with too.
Lets get it!
1roomstudio
PostPosted: Sun Nov 25, 2018 10:48 am    Post subject: Reply with quote  Mark this post and the followings unread
I use Sibelius when I want to compose in a more “classic” style (not necessarily classical)
I recently exported the audio and midi formats of a piano piece of mine and mixed the live piano with some subtle synth using the midi file.
The effect was not noticeably synth... (intentionally) but a much richer texture in the piano with upper voices popping out in a way that the piano alone would not produce.
It’s a small thing but ... maybe this technique is useful to you?
https://www.instagram.com/1roomstudio/
https://markames.bandcamp.com
https://soundcloud.com/1roomstudio
https://www.youtube.com/channel/UCdOj3y4Q55K2nUX688PDt5Q
Reality is one thing... Perception is everything
