MS-20 LPF clone problem
Page 1 of 1 [3 Posts]
palmiarz
PostPosted: Wed May 22, 2019 4:07 am    Post subject: MS-20 LPF clone problem
Subject description: it doesn't work
Hello everyone! I build MS20 LPF clone LM13700 version (Rene Schmitz project), but it doesn't work (ok, it's work unstable). Signal from my VCO (square) lost on pin 12 LM13700, where it sounds like: https://www.youtube.com/watch?v=rzDJ4xWRdE4. I don't have oscilloscope. Sorry for my english. Cheers!
ixtern
PostPosted: Wed May 22, 2019 1:00 pm    Post subject: Re: MS-20 LPF clone problem
Please provide a schematic you have used or link to that schematic. Maybe something is wrong with biasing LM13700 OTA.
I am asking for your schematic as I have found one somewhere in the Internet and it's biasing part doesn't make sense for me .
palmiarz
PostPosted: Thu May 23, 2019 1:20 am    Post subject: Reply with quote  Mark this post and the followings unread
Here is Rene's schematic: https://www.schmitzbits.de/ms20.html and here is LM13700 OTA version (which I built): https://www.lookmumnocomputer.com/projects/#/simple-filter . But yesterday I solved problem. I had connected wires between ICs V- pins and next I connected pin from one of this ICs (TL047) to supply voltage. Similarly I had with V+ pins. I disconnected this and connected supply pins to supply voltage independent. I removed decoupling caps also (2x 100nf) - but I have other decoupling caps except that.
