H
Page 1 of 1 [2 Posts]
sergeykarakich1
PostPosted: Sun Feb 22, 2015 6:46 am    Post subject: H
Subject description: S
H
Last edited by sergeykarakich1 on Wed Nov 07, 2018 5:47 pm; edited 1 time in total
Tim Kleinert
G2 patch files: 236
PostPosted: Mon Feb 23, 2015 4:10 pm    Post subject: Re: Help! Guitar pitch-shift in Muse - Map of the Problematique Reply with quote  Mark this post and the followings unread
sergeykarakich1 wrote:
Pitch-shift module is shift to right pitch (paradox) but sounds scary.
Good pitch-shifters have inbuilt auto-correlators that adjust the buffer size/crossfading to the measured periodicity of the incoming signal, thus minimizing intermodulation artefacts. The G2 pitch shifter is a trivial design that doesn't do this -hence the "scary" sound.
True auto-correlation for complex signals is impossible on the G2. Monophonic pitch detection however is possible (within reason), but you still need to design pitch-shifter algorithm that adjusts its buffer-size accordingly.
