Save chuck --status output to file
Page 1 of 1 [2 Posts]
Phloxs
PostPosted: Mon Nov 30, 2015 11:51 am    Post subject: Save chuck --status output to file Reply with quote  Mark this post and the followings unread
Hello.
How can I save output of chuck --status command to text file?
I trying to use chuck --loop > text.txt and then chuck --status,
but output of --status command saves only after chuck stoped, but i need to save output without stopping Chuck.
feltworkshop
PostPosted: Wed Dec 16, 2015 8:46 pm    Post subject: Reply with quote  Mark this post and the followings unread
like you said - looks like normal shell redirection can't capture the output of
--status in 'real time'. I tried '>>' - tee - echo `chuck file.ck` 1>file etc.
no joy
Can you piece together what you need to print inside your ChucK code & write it to file using 'file <= command...;' ?
I was hoping that Machine.status() might return something like --status but nope.
