today> Twyndyllyngs reschedule: Sunday, Dec 7 Chez Mosc
I need to make up a cable... usb to midi
Page 1 of 1 [2 Posts]
Cisco Kid
PostPosted: Fri Feb 15, 2019 9:02 am    Post subject: I need to make up a cable... usb to midi
Subject description: DIY
New to the forum. Hope I there is an answer. I am handy with micro electronics physical work... wiring/soldering etc, thru my work with DCC model rail... but now a music question
I am connecting two keyboards via midi. One has midi in and out through a Type B USB and the other midi in / out via regular midi din-type port. (This procedure works automatically with Yamaha to Yamaha connections but I am connecting Casio to Yamaha. I can see that the default channel settings should be ok on both my keyboards as is.)
There is no such thing as a straight usb to midi cable. I have tried the usb to midi y cables with the FTP processing chip in between, but that seems to prevent signal transfer. I suppose a midi processor with a pass-thru would work... but why not make up my own cable.
Does anybody have the info/diagram on pin connections for midi to usb matching. With this and the retail DIY midi and usb plugs I can make up a cord to test. Doesn't matter if usb diag is for Type A or B. I have adapters.
Thanks in advance.
MapacheRaper
PostPosted: Fri Feb 15, 2019 2:16 pm    Post subject: Reply with quote  Mark this post and the followings unread
Jan Ostman has some MIDI2CV implementations that maybe could be useful. In one of the schematics/code it shows how to build a usb/midi conversor from a attiny85 and some simple code.
https://janostman.wordpress.com/how-the-umidi2cv-works/
Not sure if is the same as you need or just similiar.
Take note tha Jan is quite famous from scamming his customers, so it´s advisable to look at the code but not bying nothing from the site, tho.
