Please help; drifting envelope
Page 1 of 1 [3 Posts]
Poster
PostPosted: Fri Jul 29, 2005 6:30 pm    Post subject: Please help; drifting envelope Reply with quote  Mark this post and the followings unread
Hi all,
I have this strange 'drifting' amp envelope..
Just a basic bass patch, nothing fancy..
Amp Attack is set to 0,5m, Decay to 45.0s, Sustain to 64, Release to 1.3s..
only short notes used, so you just hear short stabs with little to none Release..
I'am sequencing my Modular with Live..
and then..
after a minute or 2, the amp envelope starts 'drifting' like the Release is increased to max...
Has this occured to anyone before also,
or does someone know what I'am doing wrong?
If needed I can post the patch..
thanks..
Poster
Audio files: 226
PostPosted: Fri Jul 29, 2005 10:58 pm    Post subject: Reply with quote  Mark this post and the followings unread
I think you should post the patch here. I don't use Live or the NM1, just the G2, but I've seen this kind of behavior when when runs out of polyphony. I don't know if that has anything to do with what you are experienceing, but it's a thought.
Poster
PostPosted: Sat Jul 30, 2005 4:48 am    Post subject: Reply with quote  Mark this post and the followings unread
Ok thanks.. I will look into the poly suggestion..
here's the patch..
DeeBass.pch
 Filename:  DeeBass.pch
 Filesize:  2.39 KB
 Downloaded:  436 Time(s)
