 Forum index » DIY Hardware and Software » The Repair Shop
Problem with Roland M181 keyboard
Dragon's Lair
PostPosted: Fri Aug 04, 2023 1:09 pm    Post subject: Problem with Roland M181 keyboard Reply with quote  Mark this post and the followings unread
I have a weird problem with my Roland M181 keyboard, everything is working fine, except for the portamento.
The portamento actually works fine, the problem is that when you turn up the portamento time, it transposes the entire keyboard down.
With the portamento time at max it transposes the keyboard down by 2 octaves.
I have checked everything I can think of, but have no idea what is causing this.
Any suggestions would be much appreciated.
I have attached the 100m service manual
System100mServiceManual.pdf
 Filename:  System100mServiceManual.pdf
 Filesize:  6.4 MB
 Downloaded:  191 Time(s)
