<on air> Twyndyllyngs - not cancelled tonight Chez Mosc
MIDI and pulses master clock with reset
craigbarnes
PostPosted: Fri Jan 06, 2023 1:40 am    Post subject: MIDI and pulses master clock with reset Reply with quote  Mark this post and the followings unread
A friend of mine wanted to build a master clock from a GitHub page, but it used a 1602 LCD display, too big for a compact Euro rack. So I converted the display to an I2C SSD1306 0.96"display.
I added a reset output which is triggered from a button and also sends a song pointer message over midi to start position. Only works when the clock is stopped.
Technically I didn't write this code, I just made some changes, credit to the original author is on my GitHub
Specs are as follows
MIDI clock 40-280 BPM
Variable pulse width output 1-90%
Pulse outputs 1/1, 1/2, 1/4, 1/8
Reset output with MIDI song pointer
Details can be found on my GitHub page
https://github.com/craigyjp/MIDI-Master-Clock
