G2 silence when changing patches
Page 1 of 1 [3 Posts]
cappy2112
PostPosted: Sat Apr 13, 2024 10:03 pm    Post subject: G2 silence when changing patches Reply with quote  Mark this post and the followings unread
Did anyone ever solve or find a workaround for the two seconds of silence that occur when you change patches with the G2. I was just at a gig where a friend of mine was performing with the G2, when this happened. I completely forgot about that issue.
Thanks
dorremifasol
G2 patch files: 49
PostPosted: Sun Jun 02, 2024 8:11 am    Post subject: Reply with quote  Mark this post and the followings unread
I don't think that would be possible.
When sending a patch you are updating the code that runs on the DSPs. It would be impossible to keep the old code generating sound while sending the new one, since it basically ceases to exist.
Albert
Audio files: 299
PostPosted: Sun Jun 02, 2024 1:36 pm    Post subject: Reply with quote  Mark this post and the followings unread
I ended up using two G2s and a small mixer - had done that with the nm classic too btw.
