What tools to tighten nuts?
Page 1 of 1 [5 Posts]
gelg
PostPosted: Tue Feb 14, 2023 2:29 pm    Post subject: What tools to tighten nuts?
Subject description: Circuit bending
I use raised banana sockets as they're compatible with stackable patch cables which gives more options for sound mangling. But I'm sick of the process of tightening them with needle nosed pliers- it's an unpleasant chore. I've tried some vertical wrenches but they're too big and are never quite right. Does anyone have any more efficient suggestions? Many thanks
Sven
PostPosted: Wed Feb 15, 2023 12:33 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hello,
a picture would help to better understand your problem. When we now what the socket looks like its easier to help you.
Sven
Audio files: 299
PostPosted: Wed Feb 15, 2023 2:29 pm    Post subject: Re: What tools to tighten nuts?
gelg wrote:
[...]banana sockets [...] Does anyone have [...] suggestions?
Some ideas are on : https://en.wikipedia.org/wiki/Socket_wrench - I'd go for a nut driver myself, but the tube spanner thingies are quite handy too .. only thing is that you'll need to fix the nuts/rings/washers/lugs before soldering wires on ...
The tube thingies can be handy for switches with hex nuts too.
And you may want a set of the things.
gelg
PostPosted: Thu Feb 16, 2023 1:58 am    Post subject: Reply with quote  Mark this post and the followings unread
Many thanks for the replies. I found a T handle ratchet set that is small enough with multiple heads to get the job done.
Return 2 sendeR
PostPosted: Wed Jan 24, 2024 9:55 am    Post subject: Reply with quote  Mark this post and the followings unread
https://lovemyswitches.com/rocket-sockets-pedal-building-socket-set/
Been using these for a few years now. Excellent tools.
