Morphing bug with LFO frequency ranges?
paugui
G2 patch files: 37
PostPosted: Sun Aug 24, 2025 7:22 pm    Post subject: Morphing bug with LFO frequency ranges? Reply with quote  Mark this post and the followings unread
Hi all
I was creating a sound that requires the use of few LfoB modules with the same frequency but different phase, and thought it would be a good idea to use the morphing feature to change the range of the LFOs.
Sadly it doesn't seem to work.
I assigned the LFO range of one of the LFOs to a knob, so I could confirm the value is morphing, and it does show that the value is changing, but sonically, you can only notice a difference when you get to the ClkSync range...
I even tried to reset the LFOs (I sent a gate signal from the keyboard to reset them and make sure all of them are in phase), but there is no difference…
I don't think I really did morphs using variables that are controlled by switches before, so I tried to run some more tested and got the same behaviour with the LfoA module.
Or almost the same since there is no ClkSync mode tweaking the morph does absolutely nothing to the sound…
But in that same test I tried to control the range of the Frequency Shifter module and it worked without any problem…
Really not sure what to try now to fix this… If there is even a fix…
I'd expect this to be a bug but was wondering if anyone else here dealt with this before?
Thank you all in advance, best regards, Paulo
