 Forum index » How-tos
Microwave XT (before i buy)
Page 1 of 1 [16 Posts]
aquanaut
PostPosted: Tue May 04, 2004 11:20 am    Post subject: Microwave XT (before i buy) Reply with quote  Mark this post and the followings unread
I'm planning to buy this synth. does anybody have experience using it?
i've read on a site that some parameter (osc 1 semitone...) will click when you edit them. is it still the case when the parameter is modulated?
Mohoyoho
PostPosted: Tue May 04, 2004 9:28 pm    Post subject: Reply with quote  Mark this post and the followings unread
I own an XT. I haven't noticed the clicking, but I'll be using it Friday and check on it for you. I absolutely love the XT. What a unique instrument! And it's great for performance, because most of the parameters have dedicated knobs for tweeking on the fly. Since Waldorf has been hibernating, I have noticed the used XT prices are starting to creep up. It has a very aggresive tone, but it can be used for its soft ambient pads as well. I doubt you would be disappointed if you bought one at a decent price.
Mark Mahoney
Kingsport, Tennessee
www.cdbaby.com/cd/markmahoney
aquanaut
PostPosted: Wed May 05, 2004 2:24 am    Post subject: Reply with quote  Mark this post and the followings unread
the manual convinced me. sounds like a very flexible synth. i'm gonna try it tommorow but i'm afraid i'm not going to be able to test it properly in the music store. the micro q is an option too.
Mohoyoho
PostPosted: Wed May 05, 2004 7:54 am    Post subject: Reply with quote  Mark this post and the followings unread
The micro Q is very nice. I have its big brother, the Q rack. The Q is probably my favorite hardware synth in my arsenal. But the XT is fantastic too. There are tons of Micro Qs out there, but fewer XTs (probably because of the price differences.) The Micro Q's interface is not as hands-on as the XT. I would recommend getting both. They complement each other very well.
Mark Mahoney
aquanaut
PostPosted: Wed May 05, 2004 11:38 am    Post subject: Reply with quote  Mark this post and the followings unread
do you know if the micro q is seamless with program change
Mohoyoho
PostPosted: Wed May 05, 2004 12:16 pm    Post subject: Reply with quote  Mark this post and the followings unread
I don't know what you mean by seamless. But then again, I don't have a micro Q.
Mark Mahoney
aquanaut
PostPosted: Wed May 05, 2004 1:55 pm    Post subject: Reply with quote  Mark this post and the followings unread
the latency between the command from cubase and the response of the synth.
Mohoyoho
PostPosted: Wed May 05, 2004 9:48 pm    Post subject: Reply with quote  Mark this post and the followings unread
I don't have Cubase. But I do use Sonar, and I don't notice any latency.
Mark Mahoney
PostPosted: Thu May 06, 2004 5:40 am    Post subject: Reply with quote  Mark this post and the followings unread
Cubase has some "latency" settings... at least on the mac. You checked in those? As far as I know the XT is not known to be "late" Very Happy
Flickr
aquanaut
PostPosted: Thu May 13, 2004 7:56 pm    Post subject: Reply with quote  Mark this post and the followings unread
i bought the xt...now i have to reload the factory preset. i have the file from waldorf. do i simply load the file in cubase and press play...sounds to simple.
in list edit i see (F0,3E,0E,00,10,) Shocked Shocked Shocked Shocked
Thanks in advance
N[/quote][/b]
seraph
Editor
Editor
Audio files: 33
PostPosted: Thu May 13, 2004 11:52 pm    Post subject: Reply with quote  Mark this post and the followings unread
niko_91 wrote:
F0,3E,0E,00,10,
that's the beginning of a system exclusive message in hexadecimal....that's how it should be Exclamation Press play and enjoy Very Happy
aquanaut
PostPosted: Fri May 14, 2004 1:40 am    Post subject: Reply with quote  Mark this post and the followings unread
how come i don't see the entire message...i moved the column to see if i can enlarge it to see the entire mess...it look incomplete when i wrote the post.
tks
n
seraph
Editor
Editor
Audio files: 33
PostPosted: Fri May 14, 2004 1:53 am    Post subject: Reply with quote  Mark this post and the followings unread
those kind of system exclusive messages start with "F0" and end with "F7"
F7 is called EOX (End Of Exclusive). if you see an F7 at the end it means the message is complete, otherwise it could mess up your beloved XT Very Happy
Mohoyoho
PostPosted: Fri May 14, 2004 1:44 pm    Post subject: Reply with quote  Mark this post and the followings unread
Make sure Cubase' bpm is set kind of low. If Cubase won't run the midi file use Midiox. It has always worked for me. Couldn't get Sonar to send the file.
Mark Mahoney
aquanaut
PostPosted: Fri May 14, 2004 3:37 pm    Post subject: Reply with quote  Mark this post and the followings unread
ohh seraph i feel so confident now Confused Confused Confused on another matter...is there a way to edit a wavetable with mac os9? oh and did'nt found the stop levitation button...where is it Cool
Norm Vogel
PostPosted: Fri May 14, 2004 6:09 pm    Post subject: XT Reply with quote  Mark this post and the followings unread
Hi! IMHO, DEFINITELY buy an XT if you can afford one! (I'm sorry i sold mine).
This synth makes sounds like no other! If you like non-trad sounds, and "something completely different", THIS is the synth to buy!
For a sampling on the kind of way-out sounds it can make, go to my site (below), then onto the "Ambient" page.....listen to "The Scarecrow Flies At Night"......
That's 100% XT!
This synth is destined to become a Classic!
Norm
Normusic !
