today> Bill Fox solo tonight! Chez Mosc
Stripboard layout without filter?
Page 1 of 1 [4 Posts]
microscope
PostPosted: Mon Jan 30, 2006 8:57 am    Post subject: Stripboard layout without filter? Reply with quote  Mark this post and the followings unread
So I’m about to attempt Andrew Sharp’s strip board layout but from the schematic on musicfromouterspace.com it looks like there’s a version with a filter and one without. I think the stripboard layout is with the filter. Does anyone have a stripboard layout without the filter or is there an easy way to modify it? I’m kind of new at this and if there’s any way to make things a little easier I’m all for it.
Thanks
dnny
PostPosted: Tue Jan 31, 2006 1:17 pm    Post subject: Reply with quote  Mark this post and the followings unread
hi microscope and welcome to EM forum
ignore the following parts:
R7
R3
R4
R8
R10
R12
R13
R16
R20
R21
C1
C2
C3
C7
C10
LM741
(marked whit red color in picture)
and add
R1 10K to the place where R7 is.
R2 10K to the place where R3 is.
C9 1uF to the place where C1 is.
run jumper wire from R1 and R2 to C1 - marked whit green spots and grey wire in pic.
the filter is quite easy to build so think about it - it will add a lot to your WSG.
hope this helps
daniel
 Filesize:  109.45 KB
 Viewed:  5263 Time(s)
microscope
PostPosted: Wed Feb 01, 2006 7:51 am    Post subject: Thanks! Reply with quote  Mark this post and the followings unread
Thanks dnny! This helps a lot. I might try it both ways. I'll let you know what I come up with.
fluxmonkey
PostPosted: Wed Feb 01, 2006 8:13 am    Post subject: Reply with quote  Mark this post and the followings unread
absolutely... the filter doesn't add much complexity to the build, but it adds tremendously to the sound...
b
