 Forum index » Clavia Nord Modular » G2 Patches - Completed » Drum
Drum by numbers
Page 1 of 1 [7 Posts]
Rix
G2 patch files: 25
PostPosted: Mon Jun 05, 2006 6:09 am    Post subject: Drum by numbers Reply with quote  Mark this post and the followings unread
4- instrument midi drum pattern generator.
Based on the binary value of the numbers, and assignable to a a midi channel and note of your choice.
Very easy to make different drum patterns!
Richard
numberDrum.pch2
Midi drummer based on the binary values of numbers...
 Filename:  numberDrum.pch2
 Filesize:  2.21 KB
 Downloaded:  1842 Time(s)
ian-s
Audio files: 42
G2 patch files: 626
PostPosted: Mon Jun 05, 2006 12:24 pm    Post subject: Reply with quote  Mark this post and the followings unread
Interesting idea, thanks for sharing.
Rix
G2 patch files: 25
PostPosted: Tue Jun 06, 2006 11:06 am    Post subject: Reply with quote  Mark this post and the followings unread
I was wondering if the patch could be simplified.
It takes up already all memory while it consists of simple gates, one would say...
ian-s
Audio files: 42
G2 patch files: 626
PostPosted: Tue Jun 06, 2006 11:33 am    Post subject: Reply with quote  Mark this post and the followings unread
I wondered the same thing. Your arrangement of gates is perfectly correct. It's just that the logic modules seem to take a disproportionate amount of resources.
I tried your basic idea, implemented another way, uses a little less dsp.
numDrum2.pch2
another way of doing it.
 Filename:  numDrum2.pch2
 Filesize:  2.98 KB
 Downloaded:  2187 Time(s)
PostPosted: Tue Jun 06, 2006 11:47 am    Post subject: Reply with quote  Mark this post and the followings unread
The OR gates can be replaced by 8 input mixers. this will reduce the memory load somewhat (to about 66%), and the cycles as well (to 13.2%).
Not as good as Ian's sugestion though :D
Rix
G2 patch files: 25
PostPosted: Tue Jun 06, 2006 12:16 pm    Post subject: Reply with quote  Mark this post and the followings unread
Well Ian,
I am ..... speachless. This is a very elegant solution.
mother misty
G2 patch files: 130
PostPosted: Thu Jun 08, 2006 12:30 am    Post subject: Reply with quote  Mark this post and the followings unread
This is cool!
Thanks for sharing Rix!
