Morph between variations?
Page 1 of 1 [2 Posts]
Baby
PostPosted: Sat Jun 17, 2006 6:16 pm    Post subject: Morph between variations? Reply with quote  Mark this post and the followings unread
As I'm starting to work with my G2, I am realizing something that might make the variation feature more usable.
Could the values that change from variation to variation be morphed when changing with a time constant?
Now if you change variation while a note is playing, it glitches.
It would be better if it didn't.
PostPosted: Sat Jun 17, 2006 6:33 pm    Post subject: Reply with quote  Mark this post and the followings unread
Could be a very good idea.
Meanwhile / FTTB you can use constant modules to paramterize your patch.
When you lead the constant through a glide module before going to the param input it comtols you can create smooth fades.
For params that have no input it can be done with a constant connected to a midi CC send, where the param is made to listen to that CC. It coul be abstracted a bit by adding a morph layer inbetween, with the morph knob listening to the CC. This should be de-zippered I think, well in the last patch I made this way I had no zipper noises.
Requires quite some planing and work this way though, I would certainly like something easier Very Happy
