 Forum index » Instruments and Equipment » Reaktor
How to make a Delay Feedback Loop in R5
Page 1 of 1 [6 Posts]
borgnagar
PostPosted: Fri Jan 12, 2007 4:44 am    Post subject: How to make a Delay Feedback Loop in R5 Reply with quote  Mark this post and the followings unread
Anyone have ideas how to make a very nice feedback control for delays? Perhaps coupling it with nice saturation to prevent the signal from overloading. Any tips are welcome.
Dovdimus Prime
Audio files: 6
PostPosted: Sun Jan 14, 2007 3:46 pm    Post subject: Reply with quote  Mark this post and the followings unread
Don't know if you were looking for something cleverer than this but I would do something like this example:
Just stick in a one-tap delay, and add the output of the delay back into the input. You can stick any effects module you want between the output and the input, and further effects if you want them before adding the delay to the dry signal.
Does that make any sense?
 Filename:  Delay.bmp
 Filesize:  433.46 KB
 Downloaded:  1040 Time(s)
This message was brought to you from Beyond The Grave.
Dovdimus Prime
Audio files: 6
PostPosted: Sun Jan 14, 2007 3:50 pm    Post subject: Reply with quote  Mark this post and the followings unread
Sorry, I realise I could have arranged the modules so that you can see the wires more easily, but basically it goes something like:
Feed signal into single delay, then through square root, then filter, then add back into the single delay's input.
Add output of filter back into dry signal.
Dovdimus Prime
Audio files: 6
PostPosted: Sun Jan 14, 2007 3:52 pm    Post subject: Reply with quote  Mark this post and the followings unread
Oh yeah, it's important to have an amp/mixer module in the feedback loop to stop the signal just getting louder. But you knew that. Very Happy
borgnagar
PostPosted: Mon Jan 15, 2007 1:33 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks. What's the purpose of the square root? It looks like you connected the feedback loop from the pro-52 filter, is that correct?
Dovdimus Prime
Audio files: 6
PostPosted: Fri Jan 19, 2007 4:48 am    Post subject: Reply with quote  Mark this post and the followings unread
The square root is just an arbitrary effects module. I just like the sound it makes and the fact the output converges towards +1.
And yes, the filter outputs into the amp/mixer, so is involved in the delay loop.
