| Is there an interest in Super Controller PCBs? |
| Yes, by all means. |
95% |
[ 23 ] |
| No, it just doesn't cut the mustard, i think. |
0% |
[ 0 ] |
| I don't know. I mean, i... er... |
4% |
[ 1 ] |
| Total Votes : 24 |
Luka
Luka
Luka
mark_olson
Joined: Oct 26, 2006 Posts: 177 Location: Lawrence, Kansas
Posted: Fri Jul 31, 2009 7:38 pm Post subject:
| Luka wrote: | ...is everyone using rotaries for s1, s2, s4 ?
...can this be done with toggles? |
I am sourcing parts and working out a panel for this module right now so the issues associated with it are on my mind. I am using rotaries for those three but you can definitely do it with toggles. Here's a link to fonik's schematic:
http://www.modular.fonik.de/files/ononon.gif
I think he posted an english translation on the em forum once but I can't find it - the picture tells the story well enough though, I think.
Good luck,
Mark |
Luka
Luka
Posted: Mon Aug 24, 2009 6:07 am Post subject:
| Luka wrote: | well mine is pretty much working except for noise
is the ha17458 a swap for a lm1458? |
you could use any common dual opamp with same layout. i think i used a TL072.
what's the issue? _________________
Tech Buddy at Random*Source |
Luka
Posted: Mon Aug 24, 2009 6:22 am Post subject:
oh cool ill try swap it out
well my noise is not working
im just getting a 5.5 dc offset from the out jack
my wiring on this module has been really bad hehe
i really should read the build docs more thoroughly before wiring
ive had to rewire almost the entire thing  _________________ problemchild
melbourne australia
http://www.last.fm/user/prblmchild |
Tronato
Posted: Sun May 02, 2010 11:02 am Post subject:
Silence |
Hello all!
Not much talk about the Super Controller for some time now... what happened?
Did anybody succesfully build and use one?
Any samples?
Have a nice weekend!
TRON |
SolderSmoke
Posted: Sun May 02, 2010 11:06 am Post subject:
| Have anybody made an MOTM frontpanel for this? |
new voodoo
Posted: Sat Nov 30, 2013 4:38 pm Post subject:
just, you know, in case smeone wants to MAKE MORE..id be down for a few..just so whoever knows..Im DEFINATELY interested..yep..me, interested. yep. jst FYI _________________ www.newvoodoodesign.com
-my creations, bends & bendable pieces
-vintage parts & tubes, IC's & audio chips
-oddities & weird
newvoodoo.blogspot.com
-bending DIY/projects
-crap |
Posted: Sun Dec 01, 2013 6:21 am Post subject:
good to know.
i am currently struggling with a new PCB design. still tryig to find the error. anyways, something is in the works, and there will be a printed eurorack front panel for this one... _________________
Dan Lavin
Joined: Nov 09, 2006 Posts: 649 Location: Spring Lake, Mi, USA
Audio files: 21
Posted: Thu Dec 05, 2013 12:34 pm Post subject:
Matthias, could the error be in the one we found with the original pcb payout? Remember there was an error in the schematic as confirmed by TH? I believe it was a transistor. _________________ Synth DIY since 1977! |
Posted: Thu Dec 12, 2013 4:07 pm Post subject:
| Dan Lavin wrote: | | Matthias, could the error be in the one we found with the original pcb payout? Remember there was an error in the schematic as confirmed by TH? I believe it was a transistor. |
thanks for the suggestion.
i can remember that error, however, the error was in the original schematic from the book and on the 1st prototype accordingly. this has been corrected both in the redrawn schematic and in the manufactured PCB.
since i made the new design from the working redrawn schematic/PCB this should not be the problem.
in fact i see 5V on the 5V rail as long as no SN76477 is in the socket. as soon as i put it in the 5V rail changes to 7V (sic!)...
alas, i had the wrong socket on the PCB in the first place and had to remove it, which did not work well. i guess i did something to the PCB when removing the socket. i am currently assembling the spare PCB. hope it works well then... _________________
Posted: Wed Jan 15, 2014 8:18 am Post subject:
so some progress. a little. i now see the 5V. obviously a fault/short in the PCB after removing the wrong socket...
okay. the sn76477 ist still not working though. ridiculous. more checks to do... _________________
infraxpert
Posted: Tue Feb 11, 2014 2:47 pm Post subject:
I would love a couple of these when they are ready.
Hope the hard work pays off. |
Posted: Tue Feb 11, 2014 2:53 pm Post subject:
thanks.
i want one more myself, too.  _________________
Ayab
Posted: Wed May 24, 2017 5:01 am Post subject:
Any news on another run of the Super Controller PCB?
I would definitely be interested if you go ahead.
Thanks  |
Posted: Tue Aug 08, 2017 1:00 pm Post subject:
With blessings from Matthias and using a Eurorack Front panel designed by Cameron Korth, and an SMT PCB for it, we are creating a new version of the Super Controller with a couple extra features. Kits, panels, and PCB's will be available through Synthcube. I am in the midst of doing the dimensioning and layout will be next.
Further status shall be reported in this thread.
Bill |
Ayab
Posted: Wed Aug 16, 2017 2:03 pm Post subject:
| State Machine wrote: | With blessings from Matthias and using a Eurorack Front panel designed by Cameron Korth, and an SMT PCB for it, we are creating a new version of the Super Controller with a couple extra features. Kits, panels, and PCB's will be available through Synthcube. I am in the midst of doing the dimensioning and layout will be next.
Bill |
Really looking forward to this and if you can send me a pm when it is done that would be great!  |
Posted: Sat Mar 10, 2018 10:52 am Post subject:
Finally the Eurorack Supercontroller front panels are completed by CJ Korth and I have completed the design and testing of the new SMT PC Board. Everything has gone well and another classic design by Thomas Henry has now been cast into the popular EURORACK modular format.
The panels and PC boards will be sold over at Synthcube later this spring.
http://synthcube.com/cart/forums.html?route=product/search&search=sn%20voice&description=true
http://synthcube.com/cart/fonitronik-en
89.48 KB |
| Viewed: |
593 Time(s) |
359.84 KB |
| Viewed: |
635 Time(s) |
94.89 KB |
| Viewed: |
575 Time(s) |
Posted: Sat Mar 10, 2018 11:13 am Post subject:
yay! _________________
Posted: Sat Mar 10, 2018 11:39 pm Post subject:
Dan Lavin
Audio files: 21
Posted: Fri Apr 06, 2018 12:38 pm Post subject:
Not sure how I missed this before today, Bill, but dang! That's great! I'll definitely be getting one of these to replace my old 19" rack version.
One question: those 2 trimmers on the back. Are you sure the screw portion will clear a rack rail? I suppose you could get the kind that have the screw facing up instead of on the side, in a pinch. _________________ Synth DIY since 1977! |
Ayab
Posted: Fri Apr 20, 2018 5:25 pm Post subject:
| Great news. Will they be stocked by Thonk in UK? |
