 Forum index » Clavia Nord Modular » G2 Performances - Noodles
derodedoos
Page 2 of 2 [27 Posts]
Goto page: Previous 1, 2
mother misty
G2 patch files: 130
PostPosted: Mon Oct 08, 2007 4:56 am    Post subject: Reply with quote  Mark this post and the followings unread
Original file was lost, replaced by a new one.
enjoy!
iPassenger
G2 patch files: 78
PostPosted: Wed Sep 03, 2008 9:27 am    Post subject: Reply with quote  Mark this post and the followings unread
mother misty wrote:
iPassenger wrote:
Perhaps it is my novice-ness (i hops so and not just incompetence) but i can't seem to get beyond a single slot (rarely above 80% at that) with my noodle attempts. Sad
That's a good start! It's not the % that counts but the results.
One of the things I like to do when I have a noodle-block (does that exist? Smile is
- save the slot and mute it.
- load it into slot b and use this as a starting point for a new noodle.
- change filters, oscillators, connections, lfo rates, sequencer settings,
effects, add/delete modules or even let the mutator loose on it.
- when you're happy, turn on slot a Smile
You don't have to patch a new noodle by the way, audio effects are also cool for noodles.
Route your slot to another slot and use cross-over filters and do totally different things
with each band for example, I like to use the scratch module as well in noodles,
just route a slot trough it and set it to x0.5 or x0.25 and filter, delay and
layer it with the original slot.
just some idea's...
Ahh, some interesting ideas there. Smile
iP (Ross)
