how to set up a visual c++ express thing for compiling ChucK
Page 3 of 3 [57 Posts]
Goto page: Previous 1, 2, 3
PostPosted: Fri Nov 02, 2007 7:03 pm    Post subject: Reply with quote  Mark this post and the followings unread
We have a "official EM ASIO" build of 1.2.1.0 on the forum too, I made the topic sticky (official is really just a nice word for saying Philippe made it). The differences between that and 1.2.1.1 are very slight, just the Envelope, something about the third clause of a "while" loop and a third thing that had to do with crashes upon pressing Ctrl+C. Nothing major but those are good updates.
moudi
PostPosted: Sat Nov 03, 2007 9:55 am    Post subject: Reply with quote  Mark this post and the followings unread
yep, i'm aware of this one, but i'd like to build an asio miniAudicle in the end. afaik i need for building a mini the source of a working compilable chuck version.
that's the reason why i'm trying to build my own asio release.
jassas
/moudi
PostPosted: Sat Nov 03, 2007 10:28 am    Post subject: Reply with quote  Mark this post and the followings unread
I thought miniAudicle was just a front end without any audio processing?
moudi
PostPosted: Sat Nov 03, 2007 5:59 pm    Post subject: Reply with quote  Mark this post and the followings unread
the following is mentioned in the mini readme:
miniAudicle binds directly to the ChucK source code to provide an internal
ChucK compiler and virtual machine. Thus, to compile the miniAudicle requires
a copy of the ChucK source code distribution. miniAudicle includes the latest
stable release of the ChucK source code in its own distribution, and provides a
symlink to this ChucK source called 'chuck'. To bind to a different version of
the ChucK source (version 1.2.0.5 or greater), unlink 'chuck' and recreate it,
linking to the root directory of the desired source distribution (i.e., the
directory enclosing src/, not src/ itself).
therefor i thought i will build an asio chuck version in advance, and bind this one to the mini...
jassas
/moudi
PostPosted: Sat Nov 03, 2007 6:13 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks for explaining, it seems you are right.
Did you get any further in compiling?
I'll attach my config files, maybe that'll be good for something. I found 'm in the src directory.
vcfg.zip
config files for chuck compile
 Filename:  vcfg.zip
 Filesize:  4.35 KB
 Downloaded:  368 Time(s)
moudi
PostPosted: Sun Nov 04, 2007 4:03 pm    Post subject: Reply with quote  Mark this post and the followings unread
wooohooot those config files made me happy Very Happy
dunno why, but it compiled successfully with your vcproj file.
hmm.. probably i'll gonna compare those vcproj files with a texteditor to find out the differences.
thx Blue Hell
/moudi
PostPosted: Sun Nov 04, 2007 4:07 pm    Post subject: Reply with quote  Mark this post and the followings unread
Glad you got it running Very Happy
