The Thomas Henry Mega Percussive Synthesizer
Page 2 of 31 [763 Posts]
Goto page: Previous 1, 2, 3, 4, ..., 29, 30, 31 Next
goodrevdoc
PostPosted: Wed Oct 24, 2007 4:50 pm    Post subject: Reply with quote  Mark this post and the followings unread
Wow. This is just amazing. Looks like I'm going to have an all TH drum modular. Between the AVD snare and bass, the clangora, the UD-1's and now this? Seems I'll be streetfighting drummers in no time at all!Thomas, as a rural white kid with marginal at best rhythm, I just have to say thanks. Not so sure my upstairs neighbors will echo my gratitude though...
-justin
Thomas Henry
PostPosted: Wed Oct 24, 2007 6:52 pm    Post subject: Reply with quote  Mark this post and the followings unread
Scott Stites wrote:
Anyway, I'd love a panel that had four of these in it.
I agree. A drum system with four of these to play with (which really wouldn't be all that expensive to build) would literally cover just about every eventuality for percussion work. Of all the drum circuits I've designed, this is the one that really is "CD quality" and ready to push your loudspeakers to their limit. Mostly it's the impact generator, but the ring modulator ain't too shabby either.
Of course, a four-banger would require an insane amount of panel drilling! But given how many dedicated modules such a system replaces (literally dozens) the extra time in the shop would be worth it.
When I tested the unit myself this last summer, I only tried drum voices, and they were very good, if I do say myself. I was amazed at all the non-drum things Scott tried on his demo. I remember when we were hashing ideas around, he kept insisting that this was more than a drum voice, perhaps more of a standalone synth geared toward non-harmonic sounds, and I think he's right. That's why I add the S to MPS.
Thomas Henry
kokoon
PostPosted: Thu Oct 25, 2007 2:54 am    Post subject: Reply with quote  Mark this post and the followings unread
how big will the PCB be? approx?
also, maybe a stripped-down (controlpanel-wise) version could be done, for systems with a stacks of these in the box.
could you estimate how many (if any) controls are not really essential?
but still, amazing machine!!!
PostPosted: Thu Oct 25, 2007 8:13 am    Post subject: Reply with quote  Mark this post and the followings unread
As big as you want the PCB it will be! Hmmmm?
No unessential controls there are!
PostPosted: Thu Oct 25, 2007 8:31 am    Post subject: Reply with quote  Mark this post and the followings unread
Flickr
Scott Stites
Audio files: 96
PostPosted: Thu Oct 25, 2007 8:45 pm    Post subject: Reply with quote  Mark this post and the followings unread
Here's one for Yoda. This is the MPS being used for - percussion!
I actually recorded this last July 06. It's the sample I dug up that made me pester Thomas to do something with it before I died from keeping my teeth clenched together about it.
It's the MPS being trigged by an LFO, through a delay, me tweaking on it. This should give you a better hint of what I've been crowing about.
Scott
megadrum_test.mp3
MPS Banging Away
 Filename:  megadrum_test.mp3
 Filesize:  977.14 KB
 Downloaded:  2581 Time(s)
My Site
Dan Lavin
Audio files: 21
PostPosted: Fri Oct 26, 2007 3:22 pm    Post subject: Reply with quote  Mark this post and the followings unread
Scott,
Loved the demo. Reminds me of a surf song drum track! You know, all toms and no snare. So this thing definitely is capable of less spacey percussion...which is good in my book!
Scott Stites
Audio files: 96
PostPosted: Fri Oct 26, 2007 6:48 pm    Post subject: Reply with quote  Mark this post and the followings unread
Yeah, I'm trying to get Annette Funicello and Frankie Avalon for the video Very Happy
Same here - that's what tripped my trigger about it to begin with - the spaciness of it is just icing on the cake for me.
I can't wait to get back into the metallic percussive portion of it - it can do that kind of stuff you hear at the end of Eno/Byrne's "Jezebel Spirit" as easily as it can do the type of drums in the sample. The architecture of it really enables it to do a lot of things.
Scott
My Site
Audio files: 227
PostPosted: Fri Oct 26, 2007 7:12 pm    Post subject: Reply with quote  Mark this post and the followings unread
Once again, wow!
PostPosted: Sat Oct 27, 2007 2:31 am    Post subject: Reply with quote  Mark this post and the followings unread
"You have no right to her!
Her husband is the head of the house!" Cool Very Happy
StephenGiles
PostPosted: Sat Oct 27, 2007 3:09 pm    Post subject: Reply with quote  Mark this post and the followings unread
Scott
Sheila by Tommy Roe!!
PostPosted: Sat Oct 27, 2007 5:04 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hmmm,...
Sheila E getting frantic on the timbales I see.
Scott Stites
Audio files: 96
PostPosted: Sat Oct 27, 2007 10:57 pm    Post subject: Reply with quote  Mark this post and the followings unread
Do you hear voices? You hear voices then you are possessed.....Shelia E.
I plugged the Klee into a couple of VCOs and the DSC2000, and I thought "Hmmm....this needs something. I know - more cowbell!"
So, I programmed up a cowbell with the MPS, and put it in. Still needs more cowbell, but what doesn't? Very Happy
Anyway, this was done with the Klee controlling everything but my spastic tweaking of the DSC2000's VCO frequency somewhere in the middle, no multi-tracking, no reverb, no eq. A little ways in I bring up the noise on the MPS for effect. The shell CV was plugged into a CV output of the Klee, and I brought that up for a while, then back down - it's apparent as a pitch change in the cowbell voice. I did include some delay for a 30 second span between 2:15 and 2:45 (applied to the whole track in that section).
Cheerio,
Scott
kowbell_klee.mp3
More cowbell!
 Filename:  kowbell_klee.mp3
 Filesize:  3.53 MB
 Downloaded:  2155 Time(s)
My Site
23isgood
PostPosted: Sun Oct 28, 2007 1:25 pm    Post subject: Reply with quote  Mark this post and the followings unread
Wow! That really sounds like a cowbell. Cool stuff fer sure.
Check out my music
julianw
PostPosted: Mon Oct 29, 2007 9:36 am    Post subject: Reply with quote  Mark this post and the followings unread
Hey Scott, nice demo! its almost on par with the Rad Monkey VLC800 digitally modeled cowbell! Wink
The Alison Project
PostPosted: Mon Oct 29, 2007 9:51 am    Post subject: Reply with quote  Mark this post and the followings unread
I am going to need more than one.
PostPosted: Mon Oct 29, 2007 3:39 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hey JulianW,
Love your avatar, not sure about the gif.
Is that Hicks?
Photon
PostPosted: Mon Oct 29, 2007 3:48 pm    Post subject: Reply with quote  Mark this post and the followings unread
PostPosted: Mon Oct 29, 2007 3:59 pm    Post subject: Reply with quote  Mark this post and the followings unread
Well,.....
Any kind of electronic device would have to be better than Hicks bashing a real cowbell! Laughing
Scott Stites
Audio files: 96
PostPosted: Tue Oct 30, 2007 10:50 am    Post subject: Reply with quote  Mark this post and the followings unread
Ooooh, God, I love that skit. I haven't watched SNL regularly in 15 years, but my brother-in-law always tunes it in when he's visiting. One of those times was when that BOC skit was on. I thought I was going to choke.
Alison P. - yeah, I'm not woofing when I say I'd love to have four of these in a single unit. The nice thing about this voice is you can dial in so many different things, it would be great to have four of them playing at the same time. Heck, you could even have four different cowbells going, which Christopher Walken would probably love......
Actually, four of them, with a nice, fat Clangora sitting in the middle....(sigh).
Cheeerios,
Scott
My Site
The Alison Project
PostPosted: Tue Oct 30, 2007 11:09 am    Post subject: Reply with quote  Mark this post and the followings unread
Cheeerios,
Scott
Don't forget the UD-1. I took my CGS drum modules out of my modular for room and planned to build a small drum module cabinet.... Now it looks like it will be a big drum module cabinet.
Plans
- CGS Cynare x2
- CGS Dual Drum sim
- CGS Dual Chime sim
- Papareil Coron DS7
- TH Clangora
- TH UD-1
and now
- TH Mega Perc x??
Supposed to be getting an ADV Snare pcb which will be a welcome addition as well.....
Hmmmm maybe my tunes will start having drums in them haha.
Thomas Henry
PostPosted: Thu Nov 01, 2007 10:50 pm    Post subject: Reply with quote  Mark this post and the followings unread
I hate premature announcements, but just have to mention that there is currently a team working on this project that goes beyond belief! Expect the unexpected.
You're probably all getting tired of my axioms by now, but here's another that has always guided me, and again it's from Oscar Wilde:
"Nothing succeeds like excess."
Team partner THeff has certainly illustrated this! You won't believe his rapid-fire commitment to the MPS.
(Wonder what I'm talking about? Well, in just a handful of days, he's got the beta test of the MPS up and running already.)
Thomas Henry
Scott Stites
Audio files: 96
PostPosted: Fri Nov 02, 2007 6:34 am    Post subject: Reply with quote  Mark this post and the followings unread
Yeah, I'd just typed one of my droney, windy emails to the team, clicked "send", and noticed another message coming through after I'd sent that one. It was from Tim, and the subject was "MPS Perfboard is complete and fully functional". I nearly fell off my chair. I did fall off when I opened it - not only did he have the perfboard done, he had pics of it with a fully completed panel, all in glorious color.
If anyone is familiar with Gary Larson's old "Far Side" cartoon: I'm the caveman chisling on the half finished rock wheel. THeff is the caveman zipping behind me in the convertible full of cavebabes.
Quite literally amazing!
Cheerios,
Scott
My Site
Alienation
PostPosted: Fri Nov 02, 2007 11:20 am    Post subject: Reply with quote  Mark this post and the followings unread
Do we get to see the pics? Theff is the "man".
goodrevdoc
PostPosted: Fri Nov 02, 2007 3:31 pm    Post subject: Reply with quote  Mark this post and the followings unread
+1 to THeff. That gent perfs like the dickens. Does this mean things are moving faster than expected?
-jusitn
