onelove
artfx!
Posted: Thu Dec 21, 2017 4:11 am Post subject:
2 pcbs here please
I'd love to finally get some Ryk going in my eurorack! |
ryktnk
Posted: Thu Dec 28, 2017 2:40 am Post subject:
Thanks for the PMs
Haven't answered all sorry, I am away until after New Year.
-ryk |
PWM
Posted: Thu Dec 28, 2017 3:43 am Post subject:
| Thanks for the update! |
electrofluff
Posted: Wed Jan 03, 2018 1:12 pm Post subject:
PM'd for 2 maybe 3. And can I just say I agree with Julian on the least expensive and most easily obtainable rotary switches  |
ppkstat
Posted: Wed Jan 03, 2018 1:18 pm Post subject:
| Maybe we could do a group buy for the slider switches if possible. It seems a much better solution that the rotaries. |
Ayab
Posted: Mon Jan 08, 2018 6:19 pm Post subject:
For builds in eurorack format Whoop-John over on Muff-Wiggler is getting ready to design a control panel pcb based on standard rotary controllers (if Ryk's main pcb run goes ahead) - so much less soldering would be involved - a great time saving and probably trouble shooting time saving!.
Of course it is personal preference but I think a well designed panel with rotaries will be really good. Also has the benefit of much lower cost. A rotaries panel is only 2 HP wider.
A group buy for the difficult to obtain sliders is fine as a one off project but the designers of pcbs and panels need to think of longer term supply. |
ryktnk
Posted: Fri Jan 12, 2018 10:10 am Post subject:
| Ayab wrote: | For builds in eurorack format Whoop-John over on Muff-Wiggler is getting ready to design a control panel pcb based on standard rotary controllers (if Ryk's main pcb run goes ahead) - so much less soldering would be involved - a great time saving and probably trouble shooting time saving!.
Hi yes I saw that.
It could be a lot nicer and more compact if he used the mini rotary switches
I posted on previous page in the thread.
-ryk |
ryktnk
Posted: Fri Jan 12, 2018 10:14 am Post subject:
Thanks for all the PMs in the last few weeks.
I havent replied to all but I have kept a database of all interested people.
As it stands there is interest for 99 PCBs !!
Havent worked out the pricing yet sorry.
PS please note this project is not for beginners, the PCB is quite tightly
spaced, and the wiring to the controls is rather complicated.
-ryk |
Ayab
Posted: Fri Jan 12, 2018 2:29 pm Post subject:
Yes those mini-rotaries could make a great minimal panel set up. Actually I already used a couple of those for a different project.
*edit* Mini rotaries available on Aliexpress for 0.55p per piece plus postage (£3.42 postage for 16 pieces to UK). Need to make sure it is the 8 position type.
If Whoop John and Julian design for the mini-rotaries and a group buy was organised would be great as this would be a size and cost saving and they are widely available too.
If a cheap source for the classic rotaries can be found I would also be very happy with a control pcb and panel for those. |
LektroiD
Joined: Aug 23, 2008 Posts: 1019 Location: Scottish Borders
Posted: Mon Feb 19, 2018 3:28 pm Post subject:
Count me in for 2x PCB sets... If switches etc. are available, count me in for those too... Thanks _________________ LektroiD |
ryktnk
Posted: Wed Feb 28, 2018 2:06 am Post subject:
Hello
A quick update . . .
I am in the middle of redesigning the PCBs so they
are easier to make and feature a more stable clock, so
it will be a bit longer before they are available.
Also I may be able to offer the kit with 8way slide switches
if enough people are interested.
-ryk |
ppkstat
Posted: Wed Feb 28, 2018 4:35 am Post subject:
| These are great news. Since you're redesigning it please consider putting a reset input. |
Rvlt
Posted: Wed Feb 28, 2018 6:07 am Post subject:
Sounds great!
and +1 for the reset input. |
LektroiD
Posted: Wed Feb 28, 2018 9:57 am Post subject:
I'll be in for the switches, basically everything x2 (pcbs, switches, etc), especially if there is a eurorack panel coming available... I'm now thinking about upping my order from 2 to 3 (depending on price of course)... _________________ LektroiD |
ryktnk
Posted: Thu Mar 08, 2018 10:37 am Post subject:
| ppkstat wrote: | | These are great news. Since you're redesigning it please consider putting a reset input. |
Hello
Just thinking about the Reset input, could you let me know
exactly how you see this functioning ?
Is it just to reset the sequence, or would it be to reset and stop
the sequence ?
-ryk |
Ayab
Posted: Fri Mar 09, 2018 8:27 am Post subject:
Great to hear that the M185 redesign is underway
Personally I think a reset input should be just to reset.
In addition reset and stop would also be useful  |
Rvlt
Posted: Mon Mar 12, 2018 6:57 am Post subject:
| A reset input that simply jumps to step 1 when it receives a rising edge of a clock signal would be super helpful. That way you can sync the sequencer properly to e.g. a DAW without having to manually press reset every time you start the DAW again. |
ryktnk
Posted: Mon Mar 12, 2018 8:42 am Post subject:
| Rvlt wrote: | | A reset input that simply jumps to step 1 when it receives a rising edge of a clock signal would be super helpful. That way you can sync the sequencer properly to e.g. a DAW without having to manually press reset every time you start the DAW again. |
Hello
To add a reset only input is quite a simple mod to the existing design.
But if it needs to be synced to the a clock is a bit more complex.
-ryk |
Rvlt
Posted: Mon Mar 12, 2018 10:04 am Post subject:
Hi ryk,
I guess the simple mod is fine, basically it's instead of pressing the reset button manually you send a trigger signal.
I usually send two clock signals to a sequencer:
- one clock signal with the "tempo" (16th, 8th, whatever..)
- and one reset signal (on each whole note, or every 2nd or 4th or so..)
This works well with my MFOS sequencer (where I added a reset input).
Best regards
Lars |
ryktnk
thresholdpeople
Posted: Thu Mar 22, 2018 3:36 pm Post subject:
| Woah! just stumbled onto this.. Amazing. I'd be in for a board or two if this is still happening. |
elcoco
Posted: Fri Mar 23, 2018 4:38 am Post subject:
Wow definitely interested in a full set whenever these get going ' ' |
azot
Posted: Tue Apr 03, 2018 1:14 pm Post subject:
| ryktnk wrote: | Hello
-ryk |
+1 |
Alfredo
Posted: Fri Apr 13, 2018 1:12 pm Post subject:
| Yes ryktnk, we are ready for your kits! |
