frijitz
Audio files: 54
Posted: Thu Aug 28, 2008 6:43 pm Post subject:
The DoubleDeka Ultrasonic VCO Subject description: Get on the bus! |
The DoubleDeka is my new VCO. From the forthcoming documentation:
"This unique VCO consists of an ultrasonic oscillator core followed by a parallel pair of waveform generators.
Each waveform generator consists of a switched multi-octave divider followed by circuitry to generate a 10-step
waveform using a set of 10 slider potentiometers. Also included are a novel synchronization circuit with two
different operating modes and a built-in "digital ring modulator" (DRM) for producing a wide variety of
synchronized and anharmonic sounds. The oscillator core is highly stable (better than 20 ppm/K in the
prototype) and features wide-range, accurate tracking (better than 0.05% over fifteen octaves). The variable
waveform generator provides fine control over an enormous range of available timbers."
PCBs have been tested and will be available -- along with kits and panels -- from bridechamber.com.
For now here are some demos:
demo01 -- switching through the octaves and then moving the sliders around.
demo02 -- with fixed waveforms, switching through all the combinations of the octave switches.
demo03 -- a patch with the two waves fed through two VCFs.
demo04 -- four waves from two units; raw sounds without filtering.
demo05 -- sweeps of a Tri VCO fed into the the sync input (two sync modes) and then into the RM input.
(Sheesh, they were in the correct order in the preview. Has anybody figured out how the ordering works?)
Ian
 Download (listen) |
| Filename: |
DDdemo05.mp3 |
1.62 MB |
| Downloaded: |
2363 Time(s) |
 Download (listen) |
| Filename: |
DDdemo04.mp3 |
1.06 MB |
| Downloaded: |
2079 Time(s) |
 Download (listen) |
| Filename: |
DDdemo03.mp3 |
941.76 KB |
| Downloaded: |
2191 Time(s) |
 Download (listen) |
| Filename: |
DDdemo02.mp3 |
1.61 MB |
| Downloaded: |
2119 Time(s) |
 Download (listen) |
| Filename: |
DDdemo01.mp3 |
598.49 KB |
| Downloaded: |
2132 Time(s) |
andrewF
Posted: Thu Aug 28, 2008 7:06 pm Post subject:
Sounds great Ian - especially like #3
Apart from the 10 step waveform generator, does this circuit have much in common with your one in Electronotes? or has it been implemented in a different way?
I still have that rack of 10 sliders awaiting a new home  |
fluxmonkey
Posted: Thu Aug 28, 2008 7:39 pm Post subject:
hot damn! i've been waiting for this one since you first hinted at it. thanks much to both you and scott!
b _________________ www.fluxmonkey.com |
frijitz
Audio files: 54
Posted: Thu Aug 28, 2008 7:51 pm Post subject:
| andrewF wrote: | Apart from the 10 step waveform generator, does this circuit have much in common with your one in Electronotes? or has it been implemented in a different way?
Prety much totally different. The core uses the LM331 V/F converter, specifically the high frequency version in the data sheet. The logic is all CMOS (as opposed to TTL) and so has a higher level of integration. The sync and DRM are new, and took some work to get to operate well.
The boards that will be available have the sliders and their drive circuits on one board and everything else on the other. This means that you would have to use the same slider as we are in order to use the board effectively. You could use other sliders, but then you would need all flying leads from the board to the pots. Not necessarily bad, just a bit more work.
Ian |
frijitz
Audio files: 54
Posted: Thu Aug 28, 2008 8:00 pm Post subject:
Ooops -- could somebody please delete the multiple posts. Don't know how it happened, but the server wasn't responding, so I tried several times. Last edited by frijitz on Thu Aug 28, 2008 8:12 pm; edited 1 time in total |
Luka
loss1234
EdisonRex
Audio files: 172
Posted: Fri Aug 29, 2008 1:15 am Post subject:
| frijitz wrote: | | Ooops -- could somebody please delete the multiple posts. Don't know how it happened, but the server wasn't responding, so I tried several times. |
Server seems good now, so your wish is fulfilled...
This is an interesting VCO indeed! _________________ Garret: It's so retro.
bugbrand
frijitz
Audio files: 54
Posted: Fri Aug 29, 2008 6:30 am Post subject:
| loss1234 wrote: | i guess i am going to have to learn how to drill holes for sliders!
are there schematics on the bridechamber page? |
The schematics will probably be available eventually. But Scott is going to have a large tooling charge to make the panel, so I want to make sure he doesn't get undercut by anyone, if you know what I mean.
It's really a pain to mount and wire up 20 sliders. I would strongly encourage folks to use the boards and panels from Scott if at all possible.
Ian |
loss1234
Scott Stites
Audio files: 96
Posted: Fri Aug 29, 2008 6:43 am Post subject:
Couldn't tell you which was my favorite sample - they all rock exceedingly......
Far frikkin' out!!!!!!!! _________________ My Site |
bugfight
Joined: Aug 02, 2007 Posts: 188 Location: Arlington, TX USA
Posted: Fri Aug 29, 2008 7:09 am Post subject:
and the mighty Queue gets ever longer....
very nice! |
frijitz
Audio files: 54
Posted: Fri Aug 29, 2008 7:30 am Post subject:
| loss1234 wrote: | | hold on. are you saying that if i buy the boards with the sliders i wont have to drill holes for the sliders? |
No, that's not what I said.
Ian |
sduck
Posted: Fri Aug 29, 2008 8:29 am Post subject:
I'll trade the holes for the sliderrs for what's behind door #2, Monty.
Seriously, it sounds very cool - I want 2! |
loss1234
Dego
Posted: Fri Aug 29, 2008 9:06 am Post subject:
I will buy 2 as soon as bridechmaber has them available  |
bugfight
Posted: Fri Aug 29, 2008 9:57 am Post subject:
uh oh, bad news.
in another thread this terrible fact was revealed:
| frijitz wrote: |
... But I'm sure it doesn't have any "juju", whatever that is.
Ian |
as such, i have lost interest.
please refund my money... |
Scott Stites
Audio files: 96
Posted: Fri Aug 29, 2008 10:00 am Post subject:
I'm thinking the core would be up in the BBD clocking range, no? _________________ My Site |
Peake
Joined: Jun 29, 2007 Posts: 1113 Location: Loss Angeles
Posted: Fri Aug 29, 2008 10:02 am Post subject:
Done with love and reverence, you'll want it. Done with bad intent, you're helping to hurt the very thing that you love.
This oscillator is a welcome addition to oscillator lore, and a grand step above mere sawtooth core designs. I'd drop in 741s and a mylar cap in the core, but that's just me  _________________ We are selling emotions, there are no emotions in a grid. -mwagener
"IC 741. Sometimes you don't want fidelity." -Small Bear Electronics Catalog |
jnuaury
Audio files: 9
Posted: Fri Aug 29, 2008 10:08 am Post subject:
| im already making room for atleast two and assuming it utilizes a 4017 ill be making a slight modification... a switch to reset the 4017 after atleast the 6th and 8th steps if this goes into the lfo range ive got myself some synchorized sequencers |
Ilanode
Posted: Fri Aug 29, 2008 10:15 am Post subject:
| frijitz wrote: | ... But I'm sure it doesn't have any "juju", whatever that is.
Juju is a guitar dominated Nigerian style of pop music. Even though I've two great Juju records by Ebenezer Obey from the 1960s I think the DoubleDeka can do without. |
frijitz
Audio files: 54
Posted: Fri Aug 29, 2008 11:34 am Post subject:
| Scott Stites wrote: | | I'm thinking the core would be up in the BBD clocking range, no? |
The core goes up to a bit over 100 kHz. Scott D. wants to bring the HF out to the panel, and we will probably do so. Anyway, the highest fundamental frequency that can be used is around 10 kHz. If you really need to go higher, you can split the waveforms up into two equal five step segments -- this works fine because you can't much in the way of harmonics above that.
Ian |
Scott Stites
Audio files: 96
Posted: Fri Aug 29, 2008 11:40 am Post subject:
Sweet - you could drive a two phase clock driving a BBD. It just gets better and better.
An MN3X07 would get up to 5.12 ms, which would put you in some fairly decent comb filter range.
It's a magic bus.....  _________________ My Site |
frijitz
Audio files: 54
Posted: Fri Aug 29, 2008 11:41 am Post subject:
| Peake wrote: | I'd drop in 741s and a mylar cap in the core, but that's just me  |
Sure, why not. You're making my point. If you start with something stable you can always degrade it if you want. But not vice versa.
Moog used his excellent ears as part of his design process. He also used other musicians'. I have no argument whatever with anyone who wants to use his originals.
Ian |
