skrasms
Joined: Feb 21, 2008 Posts: 121 Location: Portland, OR
Posted: Fri Oct 31, 2008 7:52 pm Post subject:
Getting SMT Stuff Made |
This is a little off-topic, but my application is in using programmable logic and microprocessors in audio designs.
There are some circuits I would really like to build, but they involve parts that I absolutely cannot solder myself (BGA, for example). What are the options for paying a company to do this?
I am expecting it to be very expensive; the only way I can think of off hand is to go through Gold Phoenix for SMT builds. From what I understand, that means paying $200 to get a stencil made for the circuit plus another $150 minimum order in assembly.
Are there other options? _________________ Software and Hardware Design |
Posted: Sat Nov 01, 2008 11:14 am Post subject:
Unless you have a large quantity, then the big companies are not an option. Another option is to just use components you know you can solder and stay away from BGA's altogether. If you must use BGA's, maybe a forum member, and not a big company, can offer a hand if they have the skills and equipment. Keep in mind that large BGA's are harder to re flow than other SMT devices and requires the right thermal profile based on the size of the chip and other factors. Inspection is usually done using X-Ray gear unless you wing it and see if things work when you power up. Not good. The bottom line, BGA's should be done professionally by personnel who have the right equipment to do the job reliably. Packages like QFP's, LCC's, and DIP SO devices, they are much more manageable and with practice, you can get good at soldering these types of devices in your lab.
Another route is this, you get a prefabricated development board with the devices already soldered in place, like an FPGA development board for example, or an ARM Core logic board, then build your circuit around this core logic using your PCB and interconnect. The BGA devices will already be soldered and you save yourself the hassel. There are many MCU and processor modules that are of very small form factor that are pre-built as well.
I hope these few ideas help.
Bill |
skrasms
Posted: Sat Nov 01, 2008 11:43 am Post subject:
| State Machine wrote: | Unless you have a large quantity, then the big companies are not an option. Another option is to just use components you know you can solder and stay away from BGA's altogether. If you must use BGA's, maybe a forum member, and not a big company, can offer a hand if they have the skills and equipment. Keep in mind that large BGA's are harder to re flow than other SMT devices and requires the right thermal profile based on the size of the chip and other factors. Inspection is usually done using X-Ray gear unless you wing it and see if things work when you power up. Not good. The bottom line, BGA's should be done professionally by personnel who have the right equipment to do the job reliably. Packages like QFP's, LCC's, and DIP SO devices, they are much more manageable and with practice, you can get good at soldering these types of devices in your lab.
Bill |
Thank you for the feedback. I am looking at some parts that are only available in packages without leads, where alternatives with the same functionality don't exist. I looked into the dev board for one, but it only gave connectors for half the pins (and not the half that I really need to test!).
I wonder about a service like this:
http://www.epboard.com/eproducts/icsoldering.htm
They can do custom footprint conversions and soldering. I'm sure it costs $100+, but might be worth it for prototyping.
This too:
http://www.aapcb.com/index.asp?pgid=68&gclid=CO3F-ZLQ1JYCFQ0xawodZBkI4A
$245 for 3 fully tested boards.
I'm determined to find a way :) _________________ Software and Hardware Design |
Posted: Sat Nov 01, 2008 1:12 pm Post subject:
I agree, don't give up. My advice was aimed at steering you in a good direction I saw those links for posted and they seem like a viable option For prototyping adapters, I usually purchase these and they are very good quality at reasonable price:
http://www.beldynsys.com/kits.htm
Chat more on prototyping ............
I will take a picture of an examples using these adapters later this weekend
Bill |
skrasms
Posted: Mon Dec 22, 2008 1:26 pm Post subject:
| State Machine wrote: | I agree, don't give up. My advice was aimed at steering you in a good direction :D I saw those links for posted and they seem like a viable option :D For prototyping adapters, I usually purchase these and they are very good quality at reasonable price:
Bill |
How easily do they snap apart? _________________ Software and Hardware Design |
Posted: Tue Dec 23, 2008 6:39 am Post subject:
| Quote: | How easily do they snap apart?
Very easy, no tools required. Just your hands. Just bend a 0bit to break the initial thin material between the panels and wiggle once or twice and your their. Each adapter has rows of 0.1" spaced holes to mount the headers (provided with the panels) . They fit nicely into 0.1" prototyping board like vector or any of the cheaper ones make. Even the Radio Shack ones are good for quick prototype builds and are loads cheaper then Vector.
Bill |
skrasms
Posted: Sat Dec 27, 2008 11:53 am Post subject:
| State Machine wrote: | | Quote: | How easily do they snap apart?
Very easy, no tools required. Just your hands. :wink: Just bend a 0bit to break the initial thin material between the panels and wiggle once or twice and your their. Each adapter has rows of 0.1" spaced holes to mount the headers (provided with the panels) . They fit nicely into 0.1" prototyping board like vector or any of the cheaper ones make. Even the Radio Shack ones are good for quick prototype builds and are loads cheaper then Vector. :wink:
Bill |
Thanks, that's really cool. I've been putting off buying them because they're so expensive, but it's getting to the point where I really need them. _________________ Software and Hardware Design |
urbanscallywag
Posted: Sat Dec 27, 2008 12:48 pm Post subject:
Is your problem in prototyping or manufacturing?
I've made my own SMT prototyping boards using ExpressPCB's 3 for $51 prototyping service. It ended up being much cheaper than commercial alternatives. I would like to try PCBCart to do the same thing (but they will have a much longer lead time, ExpressPCB is 3 days to your door).
For manufacturing try looking for a local small outfit to do it. A friend of mine did this recently, it was cheaper than we expected. |
skrasms
Posted: Sun Dec 28, 2008 12:46 pm Post subject:
| urbanscallywag wrote: | Is your problem in prototyping or manufacturing?
My problem is in prototyping and manufacturing. Right now I'm doing prototyping, but I'd like to look at mass production down the road.
I started this thread because I was looking at some components that I can't safely solder myself (packages that don't have leads). The thread turned into some neat options for making it easier to use what I can solder.
So if you needed to build a prototype that contained a BGA-only part, for example, how would you get it together?
I e-mailed epboard.com about their soldering service, but they never responded so I'm doubtful of their customer service.
aapcb.com is doing $95 for a single assembled board of up to 25 SMT parts right now. _________________ Software and Hardware Design |
urbanscallywag
Posted: Sun Dec 28, 2008 1:21 pm Post subject:
Ah, BGA.
The local guy says he can do BGA but he doesn't have an X-ray to inspect the joints. We were thinking to have a lot of test points to verify a fraction of the pins using LED or a logic analyzer and a generated test.
Other than that try looking at the DIY methods using hotplates or hot air or toast ovens. Start with something low cost and easy to verify (CPLD might be a good choice) and develop a method, then work on more expensive parts. |
urbanscallywag
Posted: Sun Dec 28, 2008 1:25 pm Post subject:
I forgot about SchmartBoard. They have a funny ad around with a child soldering SMT stuff with their boards.
http://www.schmartboard.com/index.asp?page=products_bga
One problem with BGA is the high density requires a board with many layers. In some cases you can't beat the complete demo board's price just for the PCB. The BeagleBoard is an example, I think the OMAP processor uses the densest BGA package there is which requires a via under every pad!
http://beagleboard.org/ |
