My Mostly MFOS Modular
Page 1 of 1 [18 Posts]
wooster
PostPosted: Sat Nov 15, 2008 6:32 pm    Post subject: My Mostly MFOS Modular Reply with quote  Mark this post and the followings unread
My mostly MFOS modular is almost done:
MFOS modules include:
3x VCO
2x ADSR
2x LFO
1x SVF
1x Dual VCA
1x Noise Cornucopia
1x S&H
There are few a other DIY modules and a MOTM kit in there too. The strip in the middle is a mult/bus. The connections in the mult are ABCDABCDABCD etc... instead of AAAABBBCCCC... to make it easier to distribute signals.
I made the case out of african mahogany.
Other photos here:
http://www.flickr.com/photos/wooster/
Thanks Ray!
bugfight
PostPosted: Sat Nov 15, 2008 6:42 pm    Post subject: Re: My Mostly MFOS Modular Reply with quote  Mark this post and the followings unread
wooster wrote:
... ABCDABCDABCD ...
great idea.
and i assume the switches connect each left bus to the right...
nice rig, too
wooster
PostPosted: Sat Nov 15, 2008 7:26 pm    Post subject: Re: My Mostly MFOS Modular Reply with quote  Mark this post and the followings unread
bugfight wrote:
great idea.
nice rig, too
Yes, that's right. The switches can also AC couple the left to the right.
JohnLRice
PostPosted: Sat Nov 15, 2008 9:47 pm    Post subject: Reply with quote  Mark this post and the followings unread
Wow! Awesome job! That's a seriously beautiful synth! The cabinet is really really nice and good choice on the patch cord colors, goes well with the case! Wink I love those great big knows too!!! Cool
toybox
PostPosted: Sat Nov 15, 2008 10:14 pm    Post subject: Reply with quote  Mark this post and the followings unread
you did beautiful work Shocked how did you do your panels vary nice
mY MusIc
http://www.myspace.com/toyboxbastard
neandrewthal
PostPosted: Sun Nov 16, 2008 12:57 am    Post subject: Reply with quote  Mark this post and the followings unread
Gorgeous! Where do you get the big knobs?
JohnLRice
PostPosted: Sun Nov 16, 2008 1:37 am    Post subject: Reply with quote  Mark this post and the followings unread
We had a "big knob" discusion here http://www.muffwiggler.com/forum/topic-1830.html
In it I mentioned this comparison Large Alco Knob Comparison The images in the comparison aren't scaled but I'm guessing the OP used the biggest Alco knobs that are 1.77 inches in diameter (PKES150B1/4)?
Pehr
PostPosted: Sun Nov 16, 2008 5:56 am    Post subject: Reply with quote  Mark this post and the followings unread
Impressive system! Cool Very Happy
I like the VCO coarse pot Wink
YouTube channel
flickr photostream
http://loxodrom.blogspot.com
wooster
PostPosted: Sun Nov 16, 2008 6:54 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks, the wood sort of glows, so I wanted "fiery" colors Twisted Evil
On the VCO's, I used the Davies #1120 (probably a cheaper Alco lookalike); they're 1.75 inches in diameter and I think I bought them from allied. The LFO knobs are a little smaller.
toybox wrote:
you did beautiful work how did you do your panels vary nice
Panels are from Front Panel Express, but I designed them with FrontDesigner. I did a writeup on how to save money by doing this here:
http://electro-music.com/forum/post-143906.html&highlight=#143906
wooster
PostPosted: Sun Nov 16, 2008 7:02 am    Post subject: Reply with quote  Mark this post and the followings unread
Using a slider for the coarse tune is probably not the best idea for stability, but I thought it would be fun Very Happy
fluxmonkey
PostPosted: Sun Nov 16, 2008 4:54 pm    Post subject: Reply with quote  Mark this post and the followings unread
Niiicce! If you'd care to share any of those FPD files, either here or the ModularSynthPanel group at Yahoo would be an appropriate place Wink
www.fluxmonkey.com
RF
Audio files: 28
PostPosted: Mon Nov 17, 2008 6:24 am    Post subject: Reply with quote  Mark this post and the followings unread
Great looking modular, wooster!
www.sdiy.org/rfeng
waveselector
PostPosted: Mon Nov 17, 2008 7:00 pm    Post subject: Reply with quote  Mark this post and the followings unread
are you using standard instrument rack rails horizontally? that's a pretty great idea - way cheaper than t-struts and less hassle than dealing with nuts & screws for them.
wooster
PostPosted: Mon Nov 17, 2008 10:34 pm    Post subject: Reply with quote  Mark this post and the followings unread
Yup - my thoughts exactly. The only trick is you have to be really careful with your measurements. That is one reason I left a gap between the two rows for the mult panel.
waveselector
PostPosted: Tue Nov 18, 2008 8:25 am    Post subject: Reply with quote  Mark this post and the followings unread
I'm assuming then that this strays from the standard MOTM screw hole spacing?
Sorry, I don't mean to detract from your great work on the modules (impressive indeed). I just thought that the rails were worth asking about.
wooster
PostPosted: Tue Nov 18, 2008 9:21 am    Post subject: Reply with quote  Mark this post and the followings unread
No, MOTM uses standard rack spacing
wooster
PostPosted: Tue Nov 18, 2008 1:43 pm    Post subject: Reply with quote  Mark this post and the followings unread
The 6U panel for svf-adsr-vca is already posted in the other thread I mentioned. Since multiple people have asked for the Krautrock phaser panel, I'll upload that too. Price is $38. Of course you may need to adjust hole size diameters to suit your pots, leds, switches, etc...
edit: Credit for the design of the phaser panel should go to "Bill and Will":
http://dragonflyalley.com/billAndWillMOTMSynth.htm
phaser.fpd
2U MOTM format panel for JH's Compact Clone Krautrock Phaser
 Filename:  phaser.fpd
 Filesize:  9.03 KB
 Downloaded:  189 Time(s)
synthmonger
PostPosted: Tue Nov 18, 2008 2:56 pm    Post subject: Reply with quote  Mark this post and the followings unread
I love that coarse pot too. Great idea Wooster!
