Good jacks and pots?
Page 1 of 1 [15 Posts]
OneOfTheseDays
PostPosted: Mon Dec 29, 2008 11:47 am    Post subject: Good jacks and pots? Reply with quote  Mark this post and the followings unread
What kind of 1/4" mono pots should I order for my synth? I need them inexpensive and they can't take up alot of space on my front panel. Also, what pots do you guys use? Add links if you can.
sduck
PostPosted: Mon Dec 29, 2008 2:16 pm    Post subject: Reply with quote  Mark this post and the followings unread
Switchcraft 112a's - from mouser.com, part number 502-112A
Scott Deyo at Bridechamber has a similar thing a bit cheaper - https://bridechamber.sslpowered.com/bridechamber.com/Jacks.html
Pots? I love spectrol 249's, but can't afford them anymore. Alpha pots are fine though. Get a mouser and/or a digikey catalog - pdf or paper, and search through them. Once you place an order, the paper catalogs are going to start arriving anyway...
bugfight
PostPosted: Mon Dec 29, 2008 2:30 pm    Post subject: Reply with quote  Mark this post and the followings unread
+1 switchcraft, it's not worth going cheap on these...
hmmmm "one of these days i'm going to dance with the gypsies"?
or "one of these days, pow"?
or ?
RF
Audio files: 28
PostPosted: Mon Dec 29, 2008 3:57 pm    Post subject: Reply with quote  Mark this post and the followings unread
It's a very bad mistake to go completely by price for jacks. I've seen some real garbage.
I have been pleased with Neutrik NYS229. Well under $1 each even in small quantities, and they are very well built. (.69 in quantity of 100 last time I bought them)
If you need the plugs, they are NYS224 - also quite nice for very reasonable price - especially in quantity.
I have literally hundreds of these in use in my system with zero issues.
Alpha pots have been good to me, too.
bruce
www.sdiy.org/rfeng
fadeddata
PostPosted: Mon Dec 29, 2008 11:32 pm    Post subject: Reply with quote  Mark this post and the followings unread
Johnson Banana Jacks Smile
http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=J150-ND
sduck
PostPosted: Tue Dec 30, 2008 3:50 pm    Post subject: Reply with quote  Mark this post and the followings unread
Fadedata may sound slightly trollish, but he has a good point - if you're early in the business of building synth modules, you might want to seriously consider using banana jacks. Especially if space is at a premium. No need for multiple panels with them, and they're very compact and reliable. If you're like me, and have over 400 1/4in jacks already installed, it's a daunting task to even consider switching, but if you're just starting out, think about it!
fadeddata
PostPosted: Tue Dec 30, 2008 7:50 pm    Post subject: Reply with quote  Mark this post and the followings unread
Didn't mean to troll...I even offered a link to the jacks everyone uses Very Happy
They really are the best. It's amazing not using mults, it changes the way you think about patching up...
-dustin
BananaPlug
PostPosted: Tue Dec 30, 2008 8:10 pm    Post subject: Reply with quote  Mark this post and the followings unread
thumb up Yes. I have some gear with decades old Johnson jacks which are looser than than new Johnson jacks but none make any scratchy sounds or have needed to be cleaned. Kind of amazing but how could any connector with all that contact area, all of which gets a good wipe every time it's used, not be more reliable than minis or even 1/4" jacks? Oh, and they are very colorful too.
Tasmanian Alkaloid
PostPosted: Wed Dec 31, 2008 4:30 pm    Post subject: Reply with quote  Mark this post and the followings unread
Yep, i'm about to house some stuffed pcb's, and i've settled for bananas. So the link that he provided has really helped me out. thanks fadeddata!
fadeddata
PostPosted: Thu Jan 01, 2009 9:36 am    Post subject: Reply with quote  Mark this post and the followings unread
Hey Tasmanian,
Make sure to check out the other colors!
-dustin
Tasmanian Alkaloid
PostPosted: Thu Jan 01, 2009 4:51 pm    Post subject: Reply with quote  Mark this post and the followings unread
I did, thanks! Now i need to work out a colour scheme for cv's & audio, and just how many i need. I'm also considering the system Buchla uses, of 3.5mm switching jacks for audio, and bananas for cv. It's a pretty smart way to keep track of a lot of panels
(apologies for hi-jacking a 1/4" thread )
stolenfat
PostPosted: Fri Jan 02, 2009 6:11 pm    Post subject: Reply with quote  Mark this post and the followings unread
do those johnston banana jacks have a ground connection?
BananaPlug
PostPosted: Sat Jan 03, 2009 9:45 am    Post subject: Reply with quote  Mark this post and the followings unread
No. There's just one wire in a banana plug patchcord. It relies on all your equipment having a common ground reference.
Banana plug 101
OneOfTheseDays
PostPosted: Sun Jan 04, 2009 12:59 pm    Post subject: Reply with quote  Mark this post and the followings unread
or ?
It's "One of these days I'm going to cut you into little pieces."
Props to whoever understands it.
buchlajoe
PostPosted: Sun Jan 04, 2009 5:37 pm    Post subject: Reply with quote  Mark this post and the followings unread
pink floyd ....
