PIC VCLFO and ADSR
Page 1 of 1 [2 Posts]
OW
PostPosted: Fri Nov 13, 2009 10:57 pm    Post subject: PIC VCLFO and ADSR Reply with quote  Mark this post and the followings unread
Hi, I want to build both electric druids VCLFO and ADSR. This is probably a really stupid question, so please excuse it if it is:
How would I used them to produce sound, as I gather neither of the do by themselves. Would I require a VCO and VCA?
Any information on this would be greatly appreciated!
okvern
PostPosted: Sun Nov 15, 2009 3:21 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hi oscillate_wildly1,
The ADSR and LFO are both control voltage generators--you use them to control some other module that processes an audio signal. They don't really make an audio signal on their own. Usually, the other module is a VCF or VCA that you're feeding the output of a VCO or noise source through. The output of the ADSR or LFO could be used to control the frequency of a VCF or the amplitude (volume) of a VCA.
Does that make sense?
Thanks,
Ole
