mounting hole dimensions?
Page 1 of 1 [2 Posts]
norman phay
PostPosted: Thu Jan 14, 2010 11:56 am    Post subject: mounting hole dimensions? Reply with quote  Mark this post and the followings unread
A quick question - what is the spacing/dimensions of the mounting holes on the JH PCBs please? Some of them seem to be the same - pilter/phaser, living VCOs and String filter for instance, a couple different, is there a database of these, for panel design use?
The Bad Producer
PostPosted: Mon Jan 25, 2010 8:05 am    Post subject: Reply with quote  Mark this post and the followings unread
Hello Norman,
I've never come across a database, but I do have a couple of boards and can make measurements of mounting holes if you don't have access to any...
Is there a particular PCB you were looking for?
Charlie
