 Forum index » Clavia Nord Modular » G2 Performances - Experimental
stuck envelope gates?
ian-s
Audio files: 42
G2 patch files: 626
PostPosted: Sat Dec 11, 2004 1:35 pm    Post subject: stuck envelope gates? Reply with quote  Mark this post and the followings unread
I think I may have found a problem with Version 1.24. Some of my prf2’s lately have been using CC64 to activate a note hold in a given slot. After playing one of these prf2s, the slots involved may have ‘stuck’ envelopes (depending on if you were in a hold state before loading a new patch). Cycling the power fixes the problem or if you prefer, load this patch, it will also unstuck any slots involved.
fixStuck.prf2
temporary fix for loading Ian's prf2's
 Filename:  fixStuck.prf2
 Filesize:  2.86 KB
 Downloaded:  1823 Time(s)
