adamon
Joined: May 15, 2009 Posts: 96 Location: Lawrence Kansas
frantik
Joined: Dec 23, 2010 Posts: 18 Location: san jose, ca
Posted: Fri Jan 07, 2011 8:51 pm Post subject:
well here's my pacman synth, my first synth build. finished last night, well.. it's almost done.. need to decide on the power source.. probably will be a 9v battery clip but also might go with the 4 AA battery pack since i have rechargeable batteries.. and/or i might add an external power supply jack. The synth runs on 3 555 oscillators (well 1 555 and 1 556) and can be configured in various ways including the Atari Punk Console
audio: http://soundcloud.com/trikome/pacman-synth
pics:
layout of the RCA jacks:
Red - Osc 1
White - Osc 2/LFO
Yellow - Monostable Osc/Atari Punk Console
Top - Out
Bottom - CV for Osc 1 & 2, Trigger for APC |
haxster
Joined: Feb 01, 2006 Posts: 246 Location: MONTEREY PARK, CA 91754
Posted: Sat Jan 08, 2011 12:07 am Post subject:
| What kind of pots are those on the pacman synth? |
frantik
Posted: Sat Jan 08, 2011 2:49 am Post subject:
| they're 1meg but i dont know anything else about them.. found them in a bin at a surplus store |
inlifeindeath
Joined: Apr 02, 2010 Posts: 316 Location: Albuquerque, NM
Posted: Sat Jan 08, 2011 7:19 am Post subject:
| i'd definately go with the 9v. i've not had good sucess with the 555/556 chips at anything under that and 4 x AA's would bring you to 6v. |
frantik
Posted: Sat Jan 08, 2011 12:04 pm Post subject:
| well i have rechargables so i's actually 4.8v but it currently works fine using the 4 AA battery pack (the recording i posted used it) |
diablojoy
Joined: Sep 07, 2008 Posts: 809 Location: melbourne australia
Posted: Sun Jan 09, 2011 12:14 am Post subject:
1 octave pedal board
salvaged from a home organ i got for free and then rehoused in some nice timber with a mfos single buss keyboard controller cct
timbers are figured maple , blackwood , jarrah and some cocobolo
finally completely finished something took a while
514.8 KB |
| Viewed: |
936 Time(s) |
2.2 MB |
| Viewed: |
896 Time(s) |
627.81 KB |
| Viewed: |
846 Time(s) |
686.76 KB |
| Viewed: |
899 Time(s) |
577.68 KB |
| Viewed: |
885 Time(s) |
davemoog
Posted: Sun Jan 09, 2011 11:17 am Post subject:
| wow! beautiful work there. |
inlifeindeath
Posted: Sun Jan 09, 2011 11:37 am Post subject:
| thats a work of art dude, awesome work! |
Juno60
Posted: Wed Jan 12, 2011 12:34 pm Post subject:
| diablojoy wrote: | | 1 octave pedal board |
this is awesome! _________________
Tech Buddy at Random*Source |
Boogdish
Joined: Sep 21, 2009 Posts: 122 Location: Bloomington, IN
Posted: Wed Jan 12, 2011 8:21 pm Post subject:
First three panels of the new cabinet are done.
1.A pair of splitters and the power switch/fuse/pilot lamp
2.Steiner VCF
3.Two Rene Schmitz VCAs.
I'm gonna get so good at engraving by the time I fill this cabinet.
emdot_ambient
Joined: Nov 22, 2009 Posts: 667 Location: Frederick, MD
Posted: Fri Jan 14, 2011 9:28 am Post subject:
Well...OK, it's not actually built yet...but it looks like it!
Finally got my first real synth panel in yesterday and stayed up til like 1:00AM installing the hardware (some of it temporary, as I didn't pay attention to pot values, just wanted to see what it would really look like, make sure all the drill holes were correct and that I didn't accidentally place some components too close to the mounting rails...it all tested out fine).
Now all I have to do is make the PCB mounting brackets, finish the last niggling circuit corrections, calibration, testing, bug fixing...oh...and of course ALL the wiring
...my camera is a piece of sh!t...
85.27 KB |
| Viewed: |
897 Time(s) |
96.99 KB |
| Viewed: |
716 Time(s) |
TekniK
Posted: Fri Jan 14, 2011 11:57 am Post subject:
| emdot_ambient wrote: | ...but it looks like it!
F |
It looks awesome,congratulations
superb graphic layout |
rosch
Posted: Fri Jan 14, 2011 1:54 pm Post subject:
very good looking indeed.
but diablojoy, that's a beauty! |
bubzy
Joined: Oct 27, 2010 Posts: 594 Location: United Kingdom
Audio files: 64
Posted: Mon Jan 17, 2011 5:45 am Post subject:
Smurf Sequencer Subject description: First finished build of 2011 |
I wanted to make a simple analog sequencer for testing purposes, but as
usual I couldn't stop myself from adding a couple more things.
It has a (binary) pattern generator, a sort of glide control, a VCO
and a filter. The buttons on the left are for step control and reset, the
connectors on the right are from top to bottom:
12V DC in, ext. CLK in, int. CLK out, CV out (sequencer), CV in (VCO),
Audio Out (VCO)
Build on blue perf as a tribute to Dave's amazing blue modular
(that 1 octave pedal board by diablojoy looks amazing, I really like the
molten plastic/organic look)
35.81 KB |
| Viewed: |
677 Time(s) |
65.13 KB |
| Viewed: |
735 Time(s) |
50.28 KB |
| Viewed: |
698 Time(s) |
SoundCloud BandCamp MixCloud Stickney Synthyards Captain Collider Twitch YouTube Last edited by PHOBoS on Mon Jan 17, 2011 8:54 am; edited 1 time in total |
inlifeindeath
Posted: Mon Jan 17, 2011 7:18 am Post subject:
| very cool sequencer! what are the DIP switches for? and could you explain the binary pattern generator a little bit? thanks! |
Posted: Mon Jan 17, 2011 8:52 am Post subject:
Smurf Sequencer Subject description: pattern generator |
| inlifeindeath wrote: | | very cool sequencer! what are the DIP switches for? and could you explain the binary pattern generator a little bit? thanks! |
The DIP switches are there to set the patterns which works as follows:
The CLK signal goes to a binary puls divider (4040). 8 outputs of this divider
are connected to the DIP switches via diodes so switch 1 on DIP A,B,C has
CLk /2 connected, switch 2 of DIP A,B,C has CLk /4 connected and so on.
The other sides of the switches are shorted together (per DIP) and connected
to inputs A,B,C of an analog multiplexer (4051). The binary code on these
inputs selects which analog input is connected to the output. These inputs are
connected to the pots to set the voltage, output is connected to an opamp
that is configured as a voltage follower. hope that clears it up a bit  _________________ "My perf, it's full of holes!"
-minus-
Posted: Mon Jan 17, 2011 10:13 am Post subject:
Re: Smurf Sequencer Subject description: First finished build of 2011 |
| PHOBoS wrote: |
...and as a tribute to the "boys in blue" too no doubt . Nice looking object! |
Joined: Jan 07, 2009 Posts: 1224 Location: Scottish Borders
Audio files: 160
Posted: Mon Jan 17, 2011 10:19 am Post subject:
Thank you Phobos , that's a cool sequencer / osc / filter combo , and i love the blue colour .
(builder of blue modular).
Audio files: 160
Posted: Mon Jan 17, 2011 10:26 am Post subject:
| bubzy wrote: | Mostly finished, modules are (left to right)
Mfos multi noise /random gate generator
mfos single chip sample and hold
thomas henry icl8038 vco
steiner synthacon filter (from the japanese guys pcb layout)
ken stones cynare cgs 47
mfos ultra simple mono mixer
belcat delay pedal (mounted onto a panel)
hip bass drum (from this forum.... sounds EXCELLENT)
still have psu to build and a little tweaking on some modules but overall its a nice rack to play with (if you'll excuse the innuendo) |
That's a good choice / selection of modules there Bubzy , You'll be sound creating for hours with your rig
Dave. |
Joined: Mar 28, 2006 Posts: 1471 Location: Kansas City, Mo USA
Posted: Mon Jan 17, 2011 4:08 pm Post subject:
A new Yusynth Diode Ladder Filter |
This filter is a clone of the VCS3 filter. The resonant response sounds gritty or bubbly depending on the setting of the resonance level and the input signal level.
This filter was fun to build and adds another 'flavor' to the synthesizer.
| The front panel of my Yusynth Diode Ladder (VCS3 filter clone) filter with two additional audio inputs. |
877.39 KB |
| Viewed: |
655 Time(s) |
| View of the PCB. I've switched to color-coded ribbon cable. You can see the four capacitors of the ladder on the right-top section of the PCB. The diodes surround the caps however they are so tiny that they don't show up that well in the photo. |
2.77 MB |
| Viewed: |
694 Time(s) |
_________________ -- Kevin
http://kevinkissinger.com |
Posted: Tue Jan 18, 2011 9:43 pm Post subject:
Just finished a Yusynth Transistor Ladder filter Subject description: a Minimoog filter clone |
This module came to life and required no troubleshooting (**hurray!!**). I just calibrated it and that was that.
As all the other Yusynth filters that I've built, the Transistor Ladder filter is clean and musical.
Yves designed the filter to be a minimoog filter clone and its rolloff -- 24db/8ve -- is noticeably more pronounced than my Aries Multimode filters (which are 12db/8ve).
| The front panel. The Yusynth design call for two inputs and I went ahead and added two additional inputs. |
1.6 MB |
| Viewed: |
681 Time(s) |
| My youngest son, Matthew (who goes by the nickname "Tom") is holding the Transistor Ladder filter to reveal its PCB and wiring. |
2.64 MB |
| Viewed: |
690 Time(s) |
