Posted: Fri Jan 28, 2011 1:41 am Post subject:
VC Master Clock with PWM - PCB run Subject description: SOLD OUT |
hi all,
for use with my KLEE and VCPS-8 sequencers i always wanted a Clock with PWM. since in those sequencers the length of the trigger out depends on the duty cycle of the clock, PWM of the clock will add live to the sequences.
here are two very short sound samples (mp3) that show what i mean. the trigger out of the sequencer is routed to the cutoff of a ssm2044 filter:
VC CLock PWM VC CLock Speed CV
BUILDING DOCS:
Documentation 9 MAR 2011
the CV Clock features a manual speed control, CV in for speed with attenuator, manual PW control, CV in for PWM with attenuVERTER(!), clock output, and an indicator LED.
the VCO creates a falling ramp. the clock pulse is derived from that falling ramp using a comparator, thus you will not have a change in timing when doing PWM!
i am taking pre-orders until 7th of FEB. PCBs should be available mid/end of february.
(see: Recommendations for PCB offers on electro-music)
SOLD OUT
the price will be:
5.-EUR/7.-USD each PCB
+ packaging & postage (revised, german postal service changed their prices)
outside europe: 2 PCBs = 3.-USD / 3+ PCBs = 5.50 USD
europe: 2 PCBs = 2.-EUR / 3+ PCBs 4.-EUR
deutschland: 2 PCBs = 1.-EUR / 3+ PCBs 1.50EUR
frontpanel suggestion (to give you an idea):
PCB layout:
Tech Buddy at Random*Source Last edited by fonik on Wed Mar 09, 2011 5:27 am; edited 7 times in total |
magman
Joined: Feb 04, 2009 Posts: 363 Location: Liverpool, UK
Posted: Fri Jan 28, 2011 1:49 am Post subject:
Fonik,
I would be interested in at least 2, possibly 3.
Regards
Magman |
RF
Audio files: 28
Posted: Fri Jan 28, 2011 6:21 am Post subject:
I'd go for three of these, Matthias
Thanks for offering...
bruce _________________ www.sdiy.org/rfeng
(Herb Deutsch to Bob Moog ~1963) |
XCenter
Posted: Fri Jan 28, 2011 6:30 am Post subject:
Zwo Platinchen für mich bitte. _________________ --
How may I be of disservice?
Music for conscious listening @ http://www.fmdelight.de/ |
emdot_ambient
Joined: Nov 22, 2009 Posts: 667 Location: Frederick, MD
Posted: Fri Jan 28, 2011 8:22 am Post subject:
Two please!
You know...I'm a huge fan of your products, fonik...but so far I haven't gotten around to building any of them!
That day will come, but it'll still be a while; I'm collecting projects for later while slowly working away on a prioritized list.  _________________ Looking for a certain ratio since 1978 |
rosch
Posted: Fri Jan 28, 2011 9:05 am Post subject:
i'd like 3 please
thank you! |
Danno Gee Ray
Joined: Sep 25, 2005 Posts: 1351 Location: Telford, PA USA
Posted: Fri Jan 28, 2011 3:06 pm Post subject:
I'd be in for 2 please. |
droffset
Joined: Feb 02, 2009 Posts: 515 Location: London area
brother303
Joined: Nov 02, 2010 Posts: 139 Location: ruhr-area/germany
Posted: Fri Jan 28, 2011 4:31 pm Post subject:
Hello,
3 for me,please.
Would it be possible to run two (or more) of these pcbs in sync to each other?
This would make it much easier to play around with two (or more) sequencers running on the same clock but with different pwm-settings.
Best regards
Greg |
diablojoy
Joined: Sep 07, 2008 Posts: 809 Location: melbourne australia
Posted: Fri Jan 28, 2011 8:10 pm Post subject:
Very nice I will take at least 4 also please mathias
if you can add a sync in , I will make that 12
the ability to sync would really be a most usefull addition
cheers |
Adam-V
Posted: Sat Jan 29, 2011 2:14 am Post subject:
Sounds great Matthias, I'll take half a dozen if this goes ahead.
Adam-V _________________ Digitalis Effect | Fractured Symmetry (www.spiralsect.com) |
Posted: Sat Jan 29, 2011 7:20 am Post subject:
diablojoy wrote: | Very nice I will take at least 4 also please mathias
cheers |
i hear you. however, the design and prototype is already finished and tested as is. _________________
Tech Buddy at Random*Source |
Posted: Sat Jan 29, 2011 7:28 am Post subject:
brother303 wrote: | Hello,
3 for me,please.
Best regards
Greg |
cool idea.
what you could do was to use only one VCO core of the 1st PCB and then route it via the TP1 wire pad to the comparator section of the 2nd PCB (or to all the others, you wanted to use. with a little bit more tweaking you could even use a switch for master/slave mode. _________________
Level5
Posted: Sat Jan 29, 2011 1:29 pm Post subject:
I'm in for 6 PCB |
glacial23
Joined: Apr 30, 2008 Posts: 32 Location: Cleveland, OH
Dego
Posted: Sun Jan 30, 2011 10:23 am Post subject:
2 pcbs please |
whomper
brother303
Posted: Sun Jan 30, 2011 2:13 pm Post subject:
fonik wrote: | cool idea.
what you could do was to use only one VCO core of the 1st PCB and then route it via the TP1 wire pad to the comparator section of the 2nd PCB (or to all the others, you wanted to use. with a little bit more tweaking you could even use a switch for master/slave mode. |
That`s exactly what I had in mind! Glad to here that it`s doable in that easy way.
What about an external input to the comperator section? For example,Din-Sync fed into the comperator,possible or not?
Best regards
Greg |
brother303
Posted: Sun Jan 30, 2011 2:14 pm Post subject:
*sorry,double post*  |
patchdub
Posted: Sun Jan 30, 2011 4:06 pm Post subject:
definitely 1 perhaps 2 _________________ www.patchdub.com |
diablojoy
Posted: Mon Jan 31, 2011 12:20 am Post subject:
hi mathias just wondering I am not sure if it can be this simple but if
I kludged an analogue switch say one section of a dg412 at c2 to provide a dump cct and sent a clock signal to the logic in would that provide a reasonable sync to a master ? I maybe completely wrong but the switch would only need to short c2 ? of course it may just make it a very odd clock or nothing at all. I still have so much to learn here
since there are 4 spst in a dg412 I was thinking it would be good for a quad unit |
Posted: Mon Jan 31, 2011 12:22 am Post subject:
brother303 wrote: | What about an external input to the comperator section? For example,Din-Sync fed into the comperator,possible or not? |
one could add multiple inputs to the comparator, sure. however, feeding a logic signal into a comparator does not make that much sense, doesn't it? _________________
Posted: Mon Jan 31, 2011 12:27 am Post subject:
diablojoy wrote: | hi mathias just wondering I am not sure if it can be this simple but if
I kludged an analogue switch say one section of a dg412 at c2 to provide a dump cct and sent a clock signal to the logic in would that provide a reasonable sync to a master ? I maybe completely wrong but the switch would only need to short c2 ? |
i would think your approac would be a kind of reset? i dunno.
i will try some options tonight. however, i'd rather tried to sync it via IC1B. _________________
donpachi
Posted: Mon Jan 31, 2011 1:16 am Post subject:
Zwei für mich, bitte  |
diablojoy
Posted: Mon Jan 31, 2011 2:33 am Post subject:
reset yes I think you would be correct if iam reading it right mfos's vco sync is done kind of a similar way in theory though the implementation is far more complex to my mind hence my concern at how simplistic i was making it
1 chip for 4 ccts and 2 resistors per cct for the logic in's
just sounds too good so I dunno either
guess I will just try it out on breadboard when i can free it up
it's got a vactrol based pan on it at the minute
thanks for taking the time  |
